these wheels considered heavy?
Old Sep 23, 2010 | 05:45 PM
acuteperformance's Avatar
acuteperformance is infamous around these parts
18x9/12 20/24lbs
monoblock on a low offset car so it's a pretty thick pad. is this considered heavy, light, average?
thanks.
michael
acute performance
Old Sep 23, 2010 | 09:03 PM
TT Surgeon's Avatar
I would say light for 19s, avg for 18s.
Old Sep 23, 2010 | 10:39 PM
what would be considered on the lighter side for 18s? keep in mind the 12" width and the pad height.
Old Sep 24, 2010 | 04:36 AM
bumperpip's Avatar
bumperpip is infamous around these parts
No info as to your particular needs or application, but keep in mind that 18" tires will outweigh 19's significantly. Stock 19's are about 23lbs. f & 24lbs. r, +/-. TT Surgeon knows his stuff--pay heed.
Old Sep 24, 2010 | 04:40 AM
bumperpip's Avatar
Sorry-I was not clear in above post. Weights I posted are for stock 19" wheels--not tires, which are quite heavier.
Old Sep 24, 2010 | 12:57 PM
my issue is rim makers will list their wheel weights but never the application. a car with lower offsets is going to have a thicker pad height which significantly increases the weight of the wheel vs a higher offset car.
i'm hoping TT Surgeon will chime in and let me know what's a light, med-light weight for 18s.
michael
acute performance
Old Sep 24, 2010 | 01:29 PM
ModBargains II's Avatar
ModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to behold
Light - In my opininion for 18" wheels would be around the sub 18 to 20 lbs mark which can be found on wheels like the Volk Racing and ADVAN Racing wheels.
Medium Light - In my opinion for 18" wheels would be around the 19 to 23 lbs mark which can be found on most of the high-end cast wheels on the market.
Old Sep 24, 2010 | 03:59 PM
landjet's Avatar
Have to agree with Mod Bargains.
Old Sep 24, 2010 | 04:03 PM
are the light wheels monoblock, reverse lip, or step? i think step will yield the lightest because of the thinner pad height.
Old Sep 24, 2010 | 04:23 PM
Monobloc 1-Piece Forged designs usually tend to be the lightest. Take for example, the BBS FI (Forged Individual):
19x8.75" wheel weighs in at 16.31 lbs!
Old Sep 24, 2010 | 04:24 PM
For what car? I see that quote taken from BBS FI's site but no mention of the application.
Old Sep 24, 2010 | 09:16 PM
WHITE S's Avatar
WHITE S is infamous around these parts
The hre comp series are also some very light weight wheels you should take a look at.
Old Sep 24, 2010 | 10:07 PM
TT Surgeon's Avatar
michael
acute performance
17-21# would be light on 18s (f/r)
med 19/22# imo
Old Sep 27, 2010 | 12:09 PM
Given that there are only two applications: BMW and Porsche. The weight of the FI (Forged Individual) wheel was from a front wheel application for a Porsche 996 or 997 - which is 19x8.75".
The US-market BBS FIs for the BMWs haven't actually hit the shores. There are a few smuggled sets here and there. But those numbers are strictly for the Porsche guys!
Old Sep 27, 2010 | 01:43 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Your assessment that lower offset wheels are heavier due to the thicker pad are not necessarily true. Some wheel companies do vary offset by simply changing pad thickness. It is crude but effective. There are other engineering methods that work better.
We usually change the shape of the wheel face to push the wheel in or out.
For example, a lower offset wheel can have a more concave face rather than a thicker backpad.
In this way, weights are kept more constant, and heavy backpads are not necessary.
michael
acute performance
Jul 29, 2019 11:13 AM
mikespeed95
Sep 14, 2015 09:48 AM
Sterlingc1975
Aug 22, 2015 02:30 PM
Phoenix604
Aug 19, 2015 10:39 PM
