wide or narrow band o2 sensors
Old Oct 2, 2010 | 12:32 PM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
does anybody know if the 997 turbo has a wide or narrow band o2 sensor, i only see 4 wires for each sensor, my research tells me a 4 wire is narrow band , is that true? the reason i am curious because i am reading between ~.4 to .75 volts on the plx gauge, i am trying to see if i can extrapolate afr reading from that. i know narrow band goes from 0 to .9 v
Old Oct 2, 2010 | 12:34 PM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
OEM are wide band.
Old Oct 2, 2010 | 03:14 PM
cgng30's Avatar
Originally Posted by venkatreddytx
OEM are wide band.
that is interesting then i am wondering why i am seeing no more then .8 v, if its wide band then it should be from 1 to 5 v unless the ecu does the conversion?
Old Oct 2, 2010 | 05:13 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Definitely wide band capabilities. Datalogging reveals this. If you throw in some e85 I bet you will see higher voltages. At idle, stoichiometric (14.7/1) bounces back and forth anywhere between 0.1-0.9v with ~.5 being stoichiometric.
Oct 27, 2015 04:49 PM
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
DetomasoGTS74
Sep 7, 2015 09:42 AM
mjdVantage
Sep 5, 2015 07:22 PM
