Diverter valve install. Hard to do?
Old Oct 31, 2010 | 09:30 AM
camdon's Avatar
camdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant futurecamdon has a brilliant future
Is this something that should be brought to a shop to do or can it be done by someone with some mechanical ability in their garage?
Old Oct 31, 2010 | 09:37 AM
Quantum's Avatar
Quantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond repute
If you have patience and dexterity you should be able to do it no problem.
Old Oct 31, 2010 | 11:45 AM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
These are extremely easy to do! If I remember right there are 3 8mm bolts that you undo and then it slides out...You remove the vacuum line...Just need to jack the car up as well...Shouldn't take you more than 30mins...
Old Oct 31, 2010 | 12:40 PM
Quantum's Avatar
It'll take a little bit more than 30 minutes. The driver side is a little bit of a pain, you'll need to most likely move the plastic intercooler pipe aside to get to one of the bolts.
Old Oct 31, 2010 | 06:25 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
It helps if somebody can help you keeping some of the surrounding hoses pulled out of your way. I also made use of several (needle) pliers.
Old Nov 2, 2010 | 11:41 AM
vividracing's Avatar
Here is how they assemble on to the turbo - http://www.vividracing.com/catalog/p...?cID=10&pID=85
I do not have one that shows removing the on the actual turbo.
Old Nov 2, 2010 | 02:08 PM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
I did mine recently with parts ordered from Vivid. Passenger side is fairly easy taking about 30 mins while the drivers side is a bit more time consuming. You will need to remove the intercooler piping on the drivers side to remove the old dv and install the new one.
Old Nov 2, 2010 | 02:12 PM
Any pics?
Old Nov 2, 2010 | 02:17 PM
PacMan Z's Avatar
Here's a quick snapshot from my iPhone 4. Drivers side turbo.
Old Nov 2, 2010 | 02:19 PM
Sweet! Mind if we use it?
Old Nov 2, 2010 | 02:26 PM
PacMan Z's Avatar
Sure, I'll take more this weekend if you like. I'm going to be under the car.....
PV=nRT.
Sep 9, 2022 06:06 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
sparks
Sep 8, 2015 03:03 PM
shifter_
Sep 8, 2015 12:07 PM
