Intercoolers...997,2 Vs 997,1...Game over...
Old Feb 17, 2011 | 02:02 PM
  #211
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
I think right now you have to go with these or with a 4K set of 5 inch ICs from protomotive.
Old Feb 17, 2011 | 09:21 PM
  #212
landjet's Avatar
For the price, the AM coolers should be 4X as good as the 997.2 coolers, and that is not the case.
Old Feb 18, 2011 | 04:48 AM
  #213
speed21's Avatar
Very accurate asssessment landjet. 1k vs 4k sure is extreme mark up. Mind boggling!
Old Mar 22, 2011 | 07:53 PM
  #214
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
Another extensive (and pretty conclusive) test was performed tonight together with my friend skandalis comparing -in same road, similar conditions and same weight- AM ICs and GT2RS ICs. Large VTG car with modded internals (cams, rods, ported heads etc) running 1.55bar boost.
We got durametric logs, VBOX figures and also video. The GT2 RS coolers performed so much better than the AM ones that we were both shocked.
Before we post more details we saw an improvement of about 20-25degrees in IATs at 100-300kms (yes you read right).
IATs were getting as high as 59 degrees with the AM ones while with the GT2rs coolers they peaked at 41 degrees at around 250kms/hr and then started dropping to around 36degr at 300kms. We actually saw even lower IATs in some other runs.
in terms of performance;
100-200kms; 5.5 vs 5.0 secs best times
100-300kms; 18.65 vs 16.93 secs
Needless to say numbers above are personal best and i wonder if they could be improved with only 1 passenger.
Ambient temps were 12 degrees(AM) vs 9 degrees (GT2RS).
We tried to keep most variables constant as much as possible so we had the same car/tune, same passengers, same fuel quality, same exact road.
This was truly a big surprise.. More to follow
Old Mar 23, 2011 | 10:02 AM
  #215
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
It was a long night...lastnight...Results were amazing...All acceleration figures were achieved at completely flat surface with 2 persons that weigh 440lb...
I couldnt believe that IATs were lower as speed was raising above 250km...Gt2RS ICs crearly outperformed very expensive and famous AM ICs...
Old Mar 23, 2011 | 12:25 PM
  #216
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Awesome! Not many ICs start lowering temps at speed (IMO this is where overly thick coolers bite you), can you post the logs?
Old Mar 23, 2011 | 12:52 PM
  #217
I am sure George will post logs in the next hours...
Old Mar 23, 2011 | 12:59 PM
  #218
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
i put these on my 2001 turbo with alpha 28s....its amazing...pull after pull the iat's are back down to ambient temps within 15-30 seconds.
Old Mar 23, 2011 | 01:53 PM
  #219
emadelta86's Avatar
This is great news to me as I'm going to use them with A30s..
Old Mar 23, 2011 | 02:01 PM
  #220
bad107's Avatar
Nice! You are limited on endtake size though as its just 1 7/8" I believe. I am pretty sure my 3" y-pipe is worthless at this point.
Old Mar 23, 2011 | 03:15 PM
  #221
emadelta86's Avatar
I'm confident they will flow enough though...member GT-TT should be putting out 600whp or so on them..
And I will stay in the ballpark of 650/700 cranck on pump...Tony says 650 on a conservative tune with room for more.
Furthemore, lets not forget that AudiKP put down 700WHP on A30s, stock ICs and stock inlet pipes.....
Old Mar 23, 2011 | 03:16 PM
  #222
earl3's Avatar
nah, pressure drop is cumulative, so there's still some benefit. Though 2x 1 7/8" fittings don't present much of a restriction below about 1000hp.
Old Mar 23, 2011 | 04:59 PM
  #223
guys,these ICs are exceptional...Now we have data from a built engine with modified VTGs and rev limit at 8000rpm!!!Even the owner couldnt believe it...
Old Mar 23, 2011 | 06:37 PM
  #224
The Bogg's Avatar
This is good info! I have the i/cs on my car and will do some datalogging once this F$#$ing snow disappears. We thought it was spring and then all of a sudden it snowed here today. Aaaaargh!!!!!
Old Mar 23, 2011 | 09:21 PM
  #225
GT-TT's Avatar
So there it is; first file is the GT2RS ICs at 9 degrees ambient
Second file is AM ICs with 12 deg ambient.
Vbox files to follow.
Dimitri will post the video
File Type: doc
File Type: doc
