DME Scan
Old Jan 7, 2011 | 07:04 PM
jangu1206's Avatar
jangu1206 is infamous around these parts
Angry DME Scan
Looking to purchase 2007 997 TT thousand miles away. The owner has done ECU software upgrade. If I am reading this correctly, looks like this guy put range 2 going to dealer for PPI and DME scan for me... Seriously thinking about walking away from the deal. Any opinion?
Range 1
4809 ignitions 531.6 hours
Range 2
1221 ignitions 531.6 hours
Range 3
329 ignitions 510.3 hours
range 4
165 ignitions 472.6 hours
Range 5
Range 6
Operation hours counter
531.7
Old Jan 7, 2011 | 07:49 PM
TT Surgeon's Avatar
May not mean a lot if the rev limiter has been bumped up over 6800 rpms, anything over will trip a error.
Old Jan 7, 2011 | 08:06 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
That looks alot like the DME reading on my car with around 12k miles. I have protomotive flash.
Old Jan 8, 2011 | 09:23 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Well, it doesn't exactly inspire confidence but I'm not sure it rises to the level of being a deal breaker. I would not worry about the 1's and 2's at all. What did the PPI reveal?
If the car has a warranty and you will be able to inspect it before purchase that would be big plus. I'm not sure this is one I'd buy sight unseen from a thousand miles away, however. Good luck.
Old Jan 8, 2011 | 10:41 AM
TT Surgeon's Avatar
If it has an eco upgrade, it no longer has a warranty.
Old Jan 8, 2011 | 03:03 PM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
A flashed 997TT will rev past 7400 correct?
Stock Engine/Fuel system has been good for 800+whp, You think a rev to 8000 is gonna hurt it?
Old Jan 8, 2011 | 03:17 PM
bbywu's Avatar
A flashed ECU doesn't necessarily have a higher rev limiter.
Old Jan 8, 2011 | 03:23 PM
thebland's Avatar
thebland is just really nicethebland is just really nicethebland is just really nicethebland is just really nice
Curious... Is there ever a need for a DME scan on a PDK transmission??
Or does the transmission type make a difference.
Old Jan 8, 2011 | 04:02 PM
drdrilz's Avatar
drdrilz is a jewel in the roughdrdrilz is a jewel in the roughdrdrilz is a jewel in the rough
i would say not. manual trans only
Old Jan 8, 2011 | 04:09 PM
Steamboat's Avatar
True, although some do. With my Evoms flash the redline/limiter was increased to 7,000 to take advantage of other ecu mapping changes which is key. It's not about making more revs for the sake of simply making more revs, it's about optimizing the power and torque curves relative to other changes made to various tuning parameters; fuel - air mixture, timing, boost, etc. It's also about keeping everything within some modicum of reasonability to maintain reliability over time and to keep motors from needlessly blowing up. Undoubtedly, some tuners achieve their objectives without having to raise rev limits.
I don't know what the absolute limit is or what what the max rpm level other tuners go to without strengthening engine internals but I'd be surprised if it's too much higher than 7,000 - 7,200. A tuner wouldn't get much business if they were known for regularly destroying motors so some sort of safety factor must be built in. Then again, that truly is a WAG on my part and it would be interesting to hear if anyone is routinely running their TT above these levels.
Old Jan 8, 2011 | 04:19 PM
Steamboat's Avatar
Probably true unless the ECU has been flashed, the rev limiter adjusted upwards and possibly other parameters tinkered with. That said, I'm not sure how much of this is even possible w/ PDK or Tip.
Old Jan 9, 2011 | 12:18 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
At 7000 rpm in these cars, I'm afraid you are simply making more revs for the sake of more revs. It will get you across 130 mph in 4th. At that point, you're way past peak tq and power is on the decline.
mantruck
Feb 19, 2016 05:23 PM
intouch1
Sep 20, 2015 06:14 AM
holmesatx
Sep 2, 2015 11:32 AM
