OEM VTG Specs (Compressor, Turbine Size &Flow)
Old Jan 19, 2011 | 11:16 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
I know it has been hard to get info on on OEM VTG Turbo spec from vendors, here they are
997.1TT
5304 988 0060 & 61:
· Max HP limit – 480 HP for the pair
· Max compressor flow – 31-32 lbs/min
· Actual CW dimensions – O.D. – 56.1mm / Inducer – 43.3mm
· TH area – 4.05ēcm
· S&W dimensions – O.D. – 48mm / Exducer – 44.5mm
997 GT2
5304 988 0080 & 81:
· Max HP limit – 530 HP for the pair
· Max compressor flow – 34 lbs/min
· Actual CW dimensions – O.D. – 56.1mm / Inducer – 45.1mm
· TH area – 4.26ēcm
· S&W dimensions – O.D. – 48mm / Exducer – 44.5mm / with 15° clip for HCF resistance and higher flow
Both of these turbos also have the following limits:
· Exhaust gas temperature – 950°C at turbine inlet (temporarily 980°C for max of 3 minutes)
· Turbocharger speed – 185,000 RPM
Old Jan 19, 2011 | 11:58 AM
SpunkyQ8's Avatar
SpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond repute
Great Info.! Though could u fetch the specs. on the 997.2 VTG's?
Old Jan 19, 2011 | 12:05 PM
I am told the 997.2TT VTG specs are the same as the GT2 VTG's
Old Jan 19, 2011 | 12:23 PM
SpunkyQ8's Avatar
Thnx again! Rep. for u
Old Jan 19, 2011 | 01:21 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
great info ..
rep for u
Old Jan 19, 2011 | 01:45 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Awesome info Venkat! Thanks for sharing! My flow peaks about 30 lbs/min/turbo which is about what these are rated. These puppies start to choke up around 5500+.
Old Jan 19, 2011 | 06:04 PM
TTdude
Your car on stock turbos, right?
Well we finally have the turbine specs, which have been a mystery.
Old Jan 19, 2011 | 06:07 PM
TTdude's Avatar
TTdude
I have the early Proto vtg upgrade which consists of 63.5 mm compressor wheel and clipped turbine but stock otherwise. Good job on getting the specs!
Old Jan 19, 2011 | 08:03 PM
Veracity's Avatar
Veracity is infamous around these parts
Originally Posted by TTdude
My MAFs peak about 30 lbs/min/turbo which is about what these are rated. These puppies start to choke up around 5500+.
Is it possible your tune isn't using the turbos to their full potential? If the stock turbos can flow 32 lb/min and yours are upgraded you should be able to flow a lot more right?
Old Jan 19, 2011 | 08:37 PM
TTdude's Avatar
I don't think so because my tune generates 1.5-1.6 bar of boost. The MAF and compressor flow are not exactly the same but not totally unrelated either which allows for some interesting comparisons. I'm sure BW bench tests their flows. Anyhow, you have to look at a compressor map to compare compressor efficiencies (which if Venkat could get his hands on one that would be a real coup ) but I believe its the trubine that limits flow in my set-up. The gt2 turbine side is larger so it can flow more air barring any other restrictions.
Old Jul 19, 2012 | 10:57 AM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
excellent thread!! Does anyone know the shaft diameter of the VTGs? Also what is the model code? are they K24/ K26??
Old Jul 20, 2012 | 02:03 PM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
For anyone interested, I just had my vgt's upgraded to 65mm billets and during that process I had my bearing and shaft replaced as well.
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
ModBargains
Aug 20, 2015 12:28 PM
oddjob142
Aug 19, 2015 12:27 PM
