Aquamist HFS3 installation my experience
Old Feb 15, 2011 | 01:56 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Last week i got my Aquamist HFS3 water/methanol injection kit from EPL and IPD Y-pipe from AwdMotorsports. First of all i want to thank both companies for their great products and service. And a big thank you to Dave and Tony at EPL for their great support, i wouldn't had it installed without them. Thank you guys.
Complete installation took us around 18 hours, have in mind that i used the old AEM fluid tube which is the same in size and matterial. Installing new lines would take another 5-6 hours of work.
Here are some pictures of installation process
Old Feb 15, 2011 | 02:03 PM
milou's Avatar
Some more pics of the installation, i made an aluminum bracket where i installed the pump (i copied EPL) The difficult part was to define which ECU cables to connect on the control unit.
Old Feb 15, 2011 | 02:08 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
will you be running 50/50? nice install
Old Feb 15, 2011 | 02:11 PM
milou's Avatar
I did a few tests on my stock Y-pipe about where to install the jets, i tried to install them on the bottom side but as Dave said the engine belt would be very close to them. So i finally installed them on the front sides of the IPD Y-pipe. Another importand thing is to make a new gauge cable because it will not be long enough to reach the glovebox.
Old Feb 15, 2011 | 02:14 PM
milou's Avatar
The fast acting valve (FAV) was installed under the bracket where the engine boot locks
milou's Avatar
No i'll be running 100% methanol
Old Feb 15, 2011 | 02:17 PM
milou's Avatar
I used both 0,9mm and 1,0mm injectors.
Here is the final look
Old Feb 15, 2011 | 02:20 PM
milou's Avatar
If you are plunning to use a water/methanol kit Aquamist is a top quality product to go with. I can provide you with valuable information to skip dificulties and save time. I hope this will help you.
Old Feb 15, 2011 | 05:36 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
rep from me to milou for the valuable info
Old Feb 15, 2011 | 10:28 PM
milou's Avatar
thank you man, it will be a great modd for your car too, imagine running racefuel boost every day
Old Feb 15, 2011 | 11:46 PM
yalmutawa's Avatar
like what am doing now am just waiting the AEM kit to fail and i'll defo buy the HSF-6
Old Feb 16, 2011 | 04:56 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
great info to share .. thanks alot milou
why you did not install the HSF-6 ??
what nozzles you are running ? size ???
Old Feb 16, 2011 | 09:03 AM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
who will be doing your tuning?
Old Feb 16, 2011 | 11:06 AM
milou's Avatar
I installed the HSF-3 because this is the one EPL recomended to me.
I'm running the 0,9mm and 1,0mm nozzles
Old Feb 16, 2011 | 11:07 AM
milou's Avatar
Todd Knighton (Protomotive)
