Too Much Engine Oil - How to Remove Some?
Old Feb 19, 2011 | 02:12 PM
Car-Narcissist's Avatar
Car-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond repute
Message Removed
Message Removed
Old Feb 19, 2011 | 02:39 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
You might be ok. If you're concerned then just drain some oil and re-add.
Old Feb 19, 2011 | 02:49 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
open bolt on one turbo tank....
Old Feb 19, 2011 | 04:02 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
did they drain both drain plugs? I made that mistake once and it was a headache...
Old Feb 19, 2011 | 05:35 PM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
If you had a dealership do the last oil change, you should be OK.
Last oil change at the dealership same thing happend to my car, called and spoke to the tech and he said they fill the car that way.
Old Feb 19, 2011 | 05:54 PM
PSTT07's Avatar
PSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nice
From what I've read in the manual if the oil level is within the three bar range you are okay...Meaning the top bar reading means it at the full mark. I couldn't find in the manual where it states how the display functions when it's over full...
If the segments are filled in up to the top line,
the oil level has reached the maximum mark.
Under no circumstances add engine oil.
7. If the bottom segment is filled in, the oil level
has reached the minimum mark.
Add engine oil immediately.
8. If the bottom segment flashes, the oil level has
dropped to below the minimum mark.
The difference between the minimum and
maximum marks on the segment display is
approx. 1.3 quarts (1.25 litres).
One segment of the display corresponds to a
top-up quantity of approx. 0.42 quarts (0.4 litre).
Old Feb 19, 2011 | 06:03 PM
jhbrennan's Avatar
On the display there is a max line and then a bar above that. If the bar above the max line is illuminated then it is overfilled...and you don't really know by how much - at least 0.4l to light up the bar but maybe more.
Old Feb 19, 2011 | 06:04 PM
jhbrennan's Avatar
Last oil change at the dealership same thing happend to my car, called and spoke to the tech and he said they fill that car that way.
Not sure I'd accept that answer...so they routinely overfill?
Old Feb 19, 2011 | 06:10 PM
That is my guess, I believe the tech I spoke to said they fill with 9 quarts instead of 8 quarts.
Last week I had my installer do an oil change and took 2 gallon cans of Mobil 1 5W40 Turbo Diesel and a filter.
After he was done my oil level is right on the middle bar.
Old Feb 19, 2011 | 06:11 PM
PSTT07's Avatar
Thanks for the info...so the thin bar above the max bar will be filled in.
Old Feb 19, 2011 | 06:24 PM
Yes you are at the max line per the book.
When I got my car back after on oil change done at my dealership all lines were filled in.
Old Feb 19, 2011 | 07:09 PM
bbywu's Avatar
Old Feb 19, 2011 | 07:40 PM
Ted's Avatar
Ted
Ted is just really niceTed is just really niceTed is just really niceTed is just really niceTed is just really nice
Get some out, not a good idea... My tech of 30-years says to never raise it to the top bar, will do more damage than not having enough oil if you get too much.
Old Feb 19, 2011 | 08:50 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
The bolts on turbos are not drains, no oil will come out. you can probably remove the oil filter a couple times to get enough out.The other way to do it would be draining the crankcase, then top it up after.
Old Feb 19, 2011 | 09:29 PM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
Draining your crankcase would be your best bet. You will only loose a few quarts. Drainng the oil tank will result in niagra falls. Make sure you replace the ring before replacing drain plug. Measure the oil that you removed and subtract at least a 1/2 quart to start with. You can always top it off. Too much oil is a no no on these cars, at least thats what my mechanic said. I keep mine 3/4 or a bit more.
