Another 68mm Billet VTG Build -- GT2 !!
I have an idea. Shotcaller. You are local to us, correct? How about you come by the shop Tuesday when I'm back in the office and I'll take you for a full tour. If the GT2 is still there you can even check it out with your own eyes. You can then come back to the forum as a neutral third party and report back on what you see. Maybe we can finally put the skepticism to bed. Lunch will be my treat.
Hey Tom: Hopefully the GT2 will be in my hands for the 1st break-in. Mr. Shotcaller can wait until we insert the new gears, Clutch, and possible engine (internal) build.
[QUOTE
So far these 68mm turbos have been responsible for 788 whp on our 6 speed 997 Turbo at 23psi, 688whp on 4 different 997 Turbo tiptronic cars at 23psi, and now 750 on a GT2 with back on what you see. [/QUOTE]
So at the same boost (23 psi) your 997 turbo did 788whp and the other 4 cars you did made 688whp
is that due to tiptronic transmition? 100 whp difference???
I believe you will find the following (I think
1. The Turbos on the Tips are slightly different than that on the manual.
2. The efficiency of the Tips and more specifically the oil bath is the culprit versus the more abundant oil flow found in the manual
)1. The Turbos on the Tips are slightly different than that on the manual.
I'll wait for Tom to answer that then
I don't see the point of running the same boost but cut timming down to reduce power, so its not programming
100WHP is HUGE difference, Tom please don't say that you mistyped
I promised Tom that would get Vbox numbers ASAP, I am 1 of 688 tip cars (i think mine may even have a bit more)! I should have car back to me sometime next week..even planning 1/4 mile track run, once it opens up for season...then we can put all this skepticism to rest once and 4 all!!!
