2 WD mode, disabling front axles
Old Apr 4, 2011 | 02:49 AM
TwinTurboM3's Avatar
TwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud of
Just put 997TT on dyno dynamics 2 WD. (mine is not a 4 WD dyno)
Hand brake one click up, PSM off.
Could not de-activate 4 WD, the front tires took 997 TT off the rollers.
So 997 TT does not go into 2 WD mode by moving hand brake 1 click up and turning PSM off.
<!-- / message --><!-- sig -->
Old Apr 4, 2011 | 04:17 AM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
it does but not completely !
i believe you have to take off the front deferential or some thing in the front deff not sure exactly but if you want me to as for you i can !
i also know that its 30 mins job
guys here in my country takes the front def off run there cars on the dyno and install it back again its like three screws
Old Apr 4, 2011 | 09:59 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Only sure way is to remove the front driveshaft ..
Old Apr 5, 2011 | 04:12 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
look to this thread ,, it will be usefull for you
https://www.6speedonline.com/forums/...ip-gt3076.html
Old Apr 5, 2011 | 05:15 AM
yalmutawa's Avatar
Its very easy and simple ..
1- first thing is you need to take out the drive shaft ( easy job )
here is the drive shaft :
2- when i started the car it moved normally , i did not take out any fuse and i checked the break if its stucked on the discs but everything was fine !
3- after that i went to the dyno to see how much HP i will get
but .. before putting the weels on the dyno roll .. i opened the fuses box Dyno tiptronic 997.1 turbo
i taked out the fuse 8 and 10 in C row,after that i started the engine but it did not move .. alot of warning signs appeared in the dash
so i repluged the fuse (8) in his place again
so it back moving normaly just ABS/PCM warning appeared on the dash but it moved
great write up thanks yousef
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
