Engine Limits vs Power -- Sharing Some Knowledge
Old Apr 23, 2011 | 04:27 AM
Boostholic's Avatar
Boostholic is infamous around these parts
Originally Posted by Tom@Champion
The 777 awhp dyno runs were done with race gas. The car otherwise was driven daily with 93 octane pump gas at a much lower power level.
What is the whp/wtq on the 93 octane??
Old Apr 23, 2011 | 06:17 AM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
It's there a difference in strength of the rods between 996 and 997? Are the part numbers different for the 997.1 and 997.2 rods? Wondering if they changed parts mid production or at the time of facelift
Old Apr 23, 2011 | 07:24 AM
ItalianStallion's Avatar
ItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant futureItalianStallion has a brilliant future
It could be a bad batch of 93 octane that caused some knock, possibly? 700whp+ ON PUMP is a pretty stout number to be running on stock internals. Either way, I think Champion's thread is to warn those of us making these levels of power. You might get away with 800whp with stock internals for years. You might make a few passes down the track and notice something is up. Compression tests seem like a cheap way of saving your engine. God forbid the compression tests come back with off pressure numbers, at least you can save yourself a new block and a chunk of money. Thank you for sharing this with us Champion Motorsports!
Old Apr 23, 2011 | 07:52 AM
edelectra's Avatar
edelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond repute
Originally Posted by TTdude
Interesting. I believe Keith's Proto car and Switzer Sledgehammer ran 850+ whp on stock internals and when opened up, no signs of bent rods. Maybe you got some knock?
+1 ran my car for a year making 850 rwhp. then took motor apart all 6 rods were perfect . has alot to do with tuning .
Old Apr 23, 2011 | 08:19 AM
cjv's Avatar
cjv
Moderator
There was no signs of detonation on any of our pistons. We did have the redline set at 7500. Our torque was 656 ft pounds using a Dyno Jet (rw).
Old Apr 23, 2011 | 08:46 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
So with 900+ Nm I'm I in danger zone
Old Apr 23, 2011 | 11:07 AM
Boostholic's Avatar
U intend to build ur engine?
Old Apr 23, 2011 | 12:55 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Well...its all up to how your ECU is tuned...when internals are stock,programmer should set maximum torque at high rpm where engine has less stress occured from torque...On the other hand on a built engine programmer can overboost the engine at low rpm to take full advantage of (usually) garett turbos...Note that in both cases hp might be the same...but torque is what bents rods and as the higher rpm it is applied,the safier for stock rods...
Old Apr 23, 2011 | 03:02 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
they look the same but there is one bearing nose missing on the 996....
Old Apr 23, 2011 | 03:03 PM
my tuner was always telling me 800Nm is the limit for the stock ones, over this number is lottery....
Old Apr 23, 2011 | 05:48 PM
bumperpip's Avatar
bumperpip is infamous around these parts
if I recall correctly, Switzer's higher-horsepower (800+hp) motors use non-vtg turbos and AM rods. Don't know about Proto, but I think they also upgrade rods etc. in high h.p. builds. Also, Tom's statement re: no knock makes perfect sense, whether one chooses to read carefully or not. GIAC, and all other responsible tuners, leave all the Porsche safes in place. To remove or dilute them would be suicidal for the tuner. Torque seems the culprit here, doesn't it? Champion should be congratulated for their transparency and honesty. As they stated, this is THEIR car, THEIR motor. They did not have to say squat about this to anybody, but shared with us all. Thanks, Champion.
Old Apr 23, 2011 | 06:31 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Congrats to CMS for the research job and for sharing the results with us. This is very interesting.
I think we cannot use one number (torque or power value) to determine how and when our rods will bend.
Otherwise we would be admitting that Porsche uses rods with tensile strenght that differs as much as 20-25% between some engines and others (taking the 700whp mark for example)...
If this is not the case, why didn't Powell blow his motor in a matter of miles at 850whp? And why does Sledgehammer still run?Divexxtreme's GT2 runs strong, etc....
Too many cars run at 700+whp to put them into the "safety factor and/or production tolerance" gap I think.
Sure torque is one key, but not the only one imo. There has to be something else that plays a role. Maybe, as someone suggested, "where" torque is produced is another key. I'm not a fan of this theory though.
My 2 cents.
Old Apr 23, 2011 | 10:39 PM
Turbo Fanatic's Avatar
700 Crank or Wheel?
I'm not an engineer, but the idea that torque (not HP) bend rods makes a lot of sense.
One thing that seems very consistent in the factory cars is that they do not seem to eclipse the 500 ft/lb torque threshold. Essentially, they have RPM dependent boost and only increase boost past the natural torque peak. The result is bigger and bigger HP numbers but relatively constant and very flat TQ numbers across the rev range. This is very different than most tuned engines running 1.6 BAR as soon as the turbos are capable of producing that much torque.
Behind the wheel, The factory cars will feel lot smoother as they build HP with RPMs. Much more like a naturally aspirated engine on steroids.
I think that 996/997.1 turbos with the metzger engines have a good chance of remaining highly desirable in the long run when the stoutness and tunability of the stock engines become more widely accepted.
Originally Posted by cjv
We learned this back in 2004. I believe this was the first set of bent rods on a 996tt. Again around 700 hp.
Old Apr 23, 2011 | 11:40 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
TQ is more the reason for killing motors than HP.. Reason why we try to oversize the turbo on many applications pushing the limits.. Also the reason why we opt for 3071s over 28s to keep the TQ down.. We do the same with all the evos we build.. I have 1 evo running 635whp on a 2.0L engine.. Do the math on that, thats 150+ per cyl.. which would be over 900whp on a 6cyl.. and trust me the rods in an evo are nothing to write home about either.. But we dial out the TQ on them with longer runner manifolds and turbos and they hold ok but are a ticking time bomb at 600+ dont get me wrong.. I have seen rods fly from the blocks with 100 less HP because the TQ will pull the rod bolts right out..
Here is what we find.. The main engine killer is this.. And i am NOT suggesting anything about Champions engine im just sharing some of my knowledge.. In no particular order..
1. Poor tune
2. Bad tank of gas ( only takes 1 bad tank and its WAY MORE COMMON than you think to get bad gas )
3. Torque
4. HIGH RPM ( not so much an issue with Porsche as they dont rev too high but an overrev will do it )
The engine i mentioned above making 635whp is on ethanol as is every car i own.. Ethanol will keep a motor alive with a poor tune longer than 93 octane will.. Its less prone to knock of course.. Its also dependent upon how you feed boost into the powerband.. If you have the HUGE peak of TQ that hits down low its more prone to hurting the motor and that has a lot to do with boost request.. its easy to get an idea on how much boost is run based on low end TQ.. if you feed the boost on gradually itll last longer..
Old Apr 24, 2011 | 01:03 AM
speed21's Avatar
Nope...no knock whatsoever. All of our tuning is done completely through the ECU with GIAC. Every tune we provide, whether in pump or race mode, is completely without knock (with full control intact), and with full lambda control.
I agree rods bent due to overload however, what methods did you use to determine whether detonation was or wasnt present within the cylinders at the time? Did you re use the pistons?
What methods did you use to determine if there was no knock/detonation? Visual inspection does not tell the full story.
