CEL = cats
Old May 9, 2011 | 09:25 AM
eccarlino's Avatar
eccarlino is infamous around these parts
Angry CEL = cats
i have a 997 tt, all stock except for HRE p40's and a full fabspeed exhaust..
about a week or more ago, i got a CEL... i havent had to opportunity to bring it in but today i did... turns out the CEL is related to the fabspeed high flow cats and they need to be replaced...
anybody have this experience? i only put about 5,000 miles on since the installation.. any suggestions on what do to from here? who to go with?
Old May 9, 2011 | 09:45 AM
bbywu's Avatar
Call Fabspeed. You should be able to disconnect the cats separately and send them to Fabspeed for a swap (if in fact they are the problem.)
FABSPEED MOTORSPORT WARRANTY INFORMATION
Fabspeed offers a lifetime limited warranty on all our systems. The lifetime warranty is offered to the original purchaser and covers materials and construction. If the system should ever have a problem, the original purchaser must send the systems back to Fabspeed for inspection and Fabspeed will repair, fix, or replace as required determined by Fabspeed’s technical staff.
Fabspeed is not responsible for any costs including (parts, labor, shipping required for service and miscellaneous) incurred by the customer for warranty.
Warranty applies to construction and materials only. There is NO warranty of sound quality as this is subjective. Please call us with questions at any time.
Old May 9, 2011 | 10:46 AM
eccarlino's Avatar
thanks, i appreciate it...
my guy who installed it called Fabspeed and they said there's a two year warranty on the cats, its been less than two years so hes going to pull some codes, send them over to fabspeed and hopefully fix this all soon
porsche said the codes were cat-related so we'll see...
i'm surprised after 5,000 miles that this would happen
Old May 9, 2011 | 11:06 AM
bbywu's Avatar
Do you have the exact OBD code?
There are a lot of reasons why a cat will go bad - fuel, frequency of driving to operating temperatures, etc.
bob
Old May 9, 2011 | 11:33 AM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Save some time and money with these bung extensions
I had the same problem on my 2008 TT. Love the sound and performance of my exhaust. I got these (takes about 15 minutes to install on the post cat bung port). Fixed the problem.
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
~~ HOW IT WORKS ~~
Old May 9, 2011 | 12:17 PM
M32911S's Avatar
M32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to behold
I think it is a common problem with the Fabspeed cats. I know they use high quality HJS cats, but this CEL occurs more often than what people are led to believe. I had the CEL go off on my M3 with Fabspeed high flow cats after around 7k miles. Fabspeed will likely have you put in spacers for the O2 sensors if you do not have them already.
Old May 9, 2011 | 01:43 PM
kcturbo's Avatar
kcturbo is infamous around these parts
Even after having my Cats replaced by Fabspeed (which they did with great service), I still get a CEL every once in a while. I bought an OBDII tool at Sears (about $90) and when ever the CEL comes on, I simply connect the OBDII tool and erase the code. It takes about 30 seconds.
Old May 9, 2011 | 01:59 PM
gmoney's Avatar
Common, rarely a bad cat but rather a finicky ecu, flash it and tell them to adjust post cat o2 sensor or install those bungs with mini cat. Simple extensions don't work well.
Old May 9, 2011 | 06:53 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Putting in bung extensions might solve the cel problem but not the problem with bad cats if that's the case.
Old May 9, 2011 | 08:37 PM
johnww's Avatar
johnww is just really nicejohnww is just really nicejohnww is just really nicejohnww is just really nice
what is the CEL code 0430?? the tech has a procedure he should follow to determine if it is the cat.
007 Vantage
Oct 8, 2015 08:35 PM
Oct 2, 2015 02:23 PM
sdg1871
Sep 29, 2015 09:30 AM
