Problems pumping gas
Old May 28, 2011 | 08:55 AM
bosco42's Avatar
bosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to beholdbosco42 is a splendid one to behold
Originally Posted by jhbrennan
Don't you get a CEL if the engine is running and gas cap is off?
I have never seen it
Old May 28, 2011 | 09:03 AM
dave29's Avatar
dave29 is just really nicedave29 is just really nicedave29 is just really nicedave29 is just really nicedave29 is just really nice
I'm in Cali and had the same problem. Switched to Shell. The stations I hit have a different nozel than the rest. End of problem.
Old May 28, 2011 | 10:52 AM
avh128996tt's Avatar
avh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to allavh128996tt is a name known to all
i use shell gas and no problem , when i use chevron or 76 i have the same problem that is mentioned above.
Old May 28, 2011 | 02:22 PM
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
Originally Posted by ScottKelly911
That's exactly what I was talking about, we don't have that rubber here in Colorado and in many other states, makes fueling up easier.
Old May 28, 2011 | 08:36 PM
GU10TG's Avatar
GU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really niceGU10TG is just really nice
A good number of our stations here in Dallas have those same rubber collars on the pumps...affects my turbo as well.
Thanks for the upside-down tip!
Cliff
Old May 28, 2011 | 11:13 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
Those vapor recovery fuel pistols in california create too much vacuum in the porsche filler neck shutting the pump off... there is a band aid fix from porsche that involves sticking a castellated plastic ring on the end of the filler neck where the cap goes that is supposed to reduce the amount of vacuum build up during refilling, and keep it from shutting off.
part# 997 201 944 00
just a note.. only works with the default black plastic filler cap... not the aluminum look cap option.
Old May 29, 2011 | 02:07 AM
llngoc's Avatar
llngoc is infamous around these parts
I just picked up my TTS yesterday and was driving from LA to San Francisco Bay Area and I had to stop by to pump gas twice due to this problem, now I know it is not my car but the gas pump.
Old May 29, 2011 | 08:32 AM
07turbo's Avatar
07turbo is infamous around these parts
Got the same issue
Asked the dealer about it and he told me to flip the nozzle upside down....that it was a common problem. Either he was too lazy to do anything or there isn't really a fix.
Another thing that found worked was not to jam the nozzle all the way in but like 3/4 way in and just squeeze about 50% of the handle. Takes forever to fill up since the flow of gas is slower but at least it doesn't stop and you dont get weird looks.
Old May 29, 2011 | 05:30 PM
stvs911tts's Avatar
stvs911tts is infamous around these parts
I always keep a hand on the nozzle while filling my '11 997tts lest it pop out; no problems here if done like that. And our pumps DO have the black vapor recovery boot in the St. Louis metro area.
Old Jun 14, 2011 | 07:54 AM
llngoc's Avatar
+1
I just called the dealer and have an appointment to get this put in tomorrow. It should take only a few minutes to put it on and it is covered by warranty. You may want to call up your dealer and get it in.
Old Jun 14, 2011 | 09:17 AM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
Originally Posted by llngoc
+1
Thanks! My car is actually at the dealer today for a CEL issue and I just called him. They are going to put the part on...which begs the question, if they know this is a problem, why do I have to ask for it??? It should be a recall issue for all North American Porsches. Anyway, thanks for the info and your timely message!
Old Jun 14, 2011 | 09:24 AM
llngoc's Avatar
Yes, I would assume that they should put on every car sold in California at least. But I guess having a 3/4 full tank is not a safety hazard to warrant a recall.
BTW, what is a CEL? (sorry for being a newbie)
Old Jun 14, 2011 | 10:06 AM
MK23's Avatar
The 3/4 tank isn't a safety issue, but having a gallon of gas spill down the side of the tank, over the paint and on to your shoes (as happened to me) is!
Maybe hopefully for you, you will not learn the magic of the the check engine light (CEL). I've owned my car 2 months and it's come on and off 3 times. My previous Mercedes had chronic CEL issues. Seems all the new fancy computer controlled ignition and emissions controls end up causing a lot of problems!
Old Jun 14, 2011 | 10:16 AM
Vic55's Avatar
Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !Vic55 Is a GOD !
I live in Cali, same issues-- took the car to Newport Porsche and they put in the "adapter" at the fuel tank opening; the car fills up nicely
Old Jun 14, 2011 | 04:51 PM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
I had similar issues when I first got my 996TT. It was enough that one time I had no idea how much was going in and ended up overfilling and having gas leaking out and draining underneath the car. It was very frustrating. My brother told me the upside down trick, and I haven't had any issues since.
