traction control issue again....
Old Jun 18, 2011 | 11:58 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
Guys, how many of you have same problem like I have.
on 1 gear its cutting off at about 4000rpm and on the 2 gear at 6000rpm.
my ecu guy analyzed everything and he is sure it's traction control system, so he switched off part of ecu responsible for traction control but still it's working !!!!!!
my car just back from germany with some new results
Old Jun 18, 2011 | 01:00 PM
Quantum's Avatar
Quantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond reputeQuantum has a reputation beyond repute
At a certain point you need to understand that you're simply over powering the traction control system and it will no longer be as smooth. The factory traction control system is limited in the sense that there aren't many people on this planet that are capable of adequately programming a factory computer. Those that say they can for the most part are lying.
Old Jun 18, 2011 | 05:30 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
I discussed this subject earlier and compare it to what Evoms faced in Txs mile last season
No one took the subject seriously
Soon they will
I believe Evoms were working on this as well I don't know if they came out with any solution for this but m sure they'll not share it if they have it
Regards
Old Jun 18, 2011 | 05:37 PM
evoms is using german guy for ecu tuning, not sure if he is able to do that.
how about all the rest U.S fast porsche cars? my car is undrivable on two first gears and sometimes on the third too
Old Jun 19, 2011 | 01:32 PM
knock knock ! anyone one?
Old Jun 20, 2011 | 08:01 AM
yalmutawa's Avatar
eheheheh i told u this issue is still too early for here !
EVOMS faced it and they pronounce that every thing is under control now
Old Jun 20, 2011 | 08:06 AM
so you wan't to tell my that my car and evoms car are the only one with this issue?
I heard there is so many fast cars around here
Old Jun 20, 2011 | 08:19 AM
sideWays_swe's Avatar
sideWays_swe is a jewel in the roughsideWays_swe is a jewel in the roughsideWays_swe is a jewel in the rough
Are you still running stock ecu? changing the ecu to aftermarket, like motec or whatever is used on high hp porsches might help?
Old Jun 20, 2011 | 08:22 AM
sure you are 100% right, but how many fast porsche running non stock ecu you know? I'm trying to keep it as simple as possible.
Old Jun 20, 2011 | 08:55 AM
I do not have an answer for you. But i hope some of the tuners can chime in here.
Old Jun 20, 2011 | 02:54 PM
yalmutawa's Avatar
I faced this couple of times
And I sensed it and recognized the source of the issue
Maybe others didn't
Why don't Evoms answer for there self in this subject ?
Old Jun 20, 2011 | 11:56 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Carol, have you tried running the car with PSM off?
Is the problem still there ?
Old Jun 21, 2011 | 12:16 AM
k_ddsl's Avatar
k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !
Milou,
Unfortunately, switching PSM off will not turn off traction control completely in our cars.
It merely raises the threshold before it begins to interfere again.
With very high powered cars, it doesn't take much effort before that threshold is breached and TC goes berserk.
Old Jun 21, 2011 | 07:19 AM
so guys any idea?
I can't believe only 2 cars have a problem
Maybe others didn't
so you have this problem too? or not?
