Clutch Pedal Feels very soft on cold start
Old Aug 19, 2011 | 03:20 PM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
This week I've noticed that when my car sits for a few days, the clutch pedal is very soft and wont come all the way up(3/4). But after pumping it a few times and driving out the neighborhood it stiffens up and operates like normal. I recall I had a similar problem a few years ago when the clutch pedal fell to the floor and wouldn't come up(due to no fluid). Is this a symptom of the same problem?
Old Aug 19, 2011 | 04:10 PM
gmoney's Avatar
Sounds like more slave or accumulator woes to me.
Old Aug 22, 2011 | 05:00 PM
What's that cost? I haven't had the car out of the shop for 2 weeks now.
Old Aug 22, 2011 | 06:12 PM
gmoney's Avatar
Only guessing, but would assume not much change from $1.5k with most of it labor.
Old Aug 22, 2011 | 06:15 PM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
Dont even play around with replacing the Accumulator, Swap to the GT2 Slave cylinder. Will definitly extend the clutch life too.
Old Aug 22, 2011 | 06:48 PM
gmoney's Avatar
+1
Probably same price to go GT2 conversion and never have a problem arise again.
Old Aug 22, 2011 | 08:52 PM
bbywu's Avatar
Originally Posted by gmoney
+1
Although, this is a pretty well known problem that may be covered even outside of warranty (if the OP's warranty has expired.)
b
Old Aug 23, 2011 | 11:42 AM
b
Great, I Had the same problem while under warranty & they said it was just low on oil. But it wasn't driveable then. Currently it gets better as I drive/warm up.
Will is slowly get worse or fail instantly?
Old Aug 23, 2011 | 12:00 PM
gmoney's Avatar
low on pentosin is right, but its leaking or backing up somewhere. I typically noticed mine going bad and then 3-4 weeks later fail.
If you have a report showing them topping it off etc. then you should be ok, push it up the ladder if they give you a hard time.
Old Aug 23, 2011 | 03:02 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I just changed the accumulator and slave cylinder on my 993tt which is probably similar to the 997tt. The parts cost was $800 and that was wholesale. I had to remove the starter and hug the transmission from underneath and unbolt the slave by feel. There is no way to see it because it lies on top of the tranny. The job absolutely kills your shoulders. The pentosin has to go somewhere and in my case it was leaking out the front reservoir in the "frunk"
Old Aug 23, 2011 | 03:29 PM
Thanks for all the help guys.
But how it is stiffening back again after driving say 2-3miles? If its low on fluid wouldn't it stay soft/close to the floor?
Old Aug 23, 2011 | 03:31 PM
Also where can I check for the "pentosin" Fluid???
Old Aug 23, 2011 | 04:13 PM
gmoney's Avatar
open frunk, drivers side, under plastic panel there is a reservoir.
Old Aug 23, 2011 | 04:32 PM
Is that the same as the brake fluid reservoir?
Old Aug 23, 2011 | 07:14 PM
gmoney's Avatar
look for the green cap on top of the reservoir. Pentosin differs from brake fluid.
