So what do you really think?
I received some nice comments but I'm sure there are those who must think this dyno is inflated, not possible, etc...! If so, let's hear what's on your mind. Don't hold back. I won't get offended. Nothing better than a good 'ol discussion to keep things interesting. All comments welcomed, 996t guys, tuners, etc...!
how many miles are on the motor? I have heard of stories of cars with 600whp needing new head gaskets; but then again their cars were not tuned by the engineering wizard Todd Knighton.
With those numbers, Dave, think it goes without saying that it/you are nuts
Whether the dyno is inflated or not is irrelevant (please refer to my prior d*ck swinging comment
). However, did you ever post your baseline numbers?
As far as what's going on with your motor at this point is anyone's guess as you're going into unchartered territory with stock internals. For your sake, I hope that the assumptions of Proto and Switzer (vs. more 'conservative' tuners) are correct in what a GT1 block can take in unmodified form. But as I mentioned to you before, I personally wouldn't risk it. I would get that engine done ASAP.
). However, did you ever post your baseline numbers? As far as what's going on with your motor at this point is anyone's guess as you're going into unchartered territory with stock internals. For your sake, I hope that the assumptions of Proto and Switzer (vs. more 'conservative' tuners) are correct in what a GT1 block can take in unmodified form. But as I mentioned to you before, I personally wouldn't risk it. I would get that engine done ASAP.
Thought 1: If you have the money to build a motor, then this is truly a fun experiment.
Thought 2: I'm still curious to see the A/Fs. Maybe ethanol + a killer tune makes for massive amounts of safe power. As far as the gaskets are concerned, you can have aftermarket ones installed with high-torque head bolts put in if you start blowing coolant, no?
EDIT: I guess what I'm getting at is, if you have the money to rebuild short block, don't chicken out. Let's see how long it can hold. You car and $$$ though.
Totally agree! Todd said if I wanted any motor work done, it would be months of waiting time. Cynthia is slammed right now. I don't want to wait any longer.
It's hopeless with guys like us. We're going to have to learn the hard way.
I don't have any baseline numbers with vtgs. They were sold to Asher a few months ago.
PS With A3076 at 16.0-16.5 psi, the car made 685 whp. This thing makes a lot more power at lower boost. Safer for the engine.
Hopefully some one can answer with some tested results.
Agreed. What would you recommend doing to strengthen motor?
