help car wash put armor all on my interior!!
Had the same thing happen to one of my cars a couple of years ago and I feel your pain. It will go away on its own, but it's slippery and unattractive to say the least.
I've had some luck using this product on leather surfaces:
http://www.glisteningperfectionstore...leather/Detail
It does not leave a greasy, or shiny appearance on leather and gets the job done.
Before applying, I'd probably use a slightly moistened towel to remove some of the Armor All first.
I would also not recommend using this car wash again.. most higher end facilities should know better!
Running your TT through a car wash - how did the rear wheels fit? I'd be more worried about wheel damage. You can use a good leather cleaner (Zaino) to clean the Armorall off.
hand wash at a car wash facility. Not the best job but it was fast and easy
I have seen many turbos go through my local machine wash and they say it fits perfectly. The tracks are wide.
It will fade off eventually. You can find some grease cutters and cleaners on autogeek if you're impatient but give it a few weeks and it'll be gone. maybe a bit longer if it's been cold up in the NE.
I would immediately buy Zymol leather cleaner and go over all of your leather several times. It's great stuff. After a few applications, and giving it a day or two to soak in, put on Zymol Treat (conditioner).
I fixed it all up tonight. All I had available to me was to go to whole foods and get the most simple eco friendly cleaner I could find. I found one that was all natural and said safe for leather. I brought it home and diluted it with water 4:1 I used a rag to dip in the mixture and gently wipe the affected areas. I then dried it with a dry towel. It all looks great now and no more greasy shine! Thanks guys.
those carwashes with the wheel guide royally f up the inside of your wheel lip, especially on cars with different front and rear offsets like ours. i dont even let the hand wash guy touch mine, not when I see the rags those guys drop on the floor and reuse and the watch / ring wearing while they do it.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
