mt street radials
Old Nov 28, 2011 | 06:42 PM
topspeedua's Avatar
topspeedua is infamous around these parts
mt street radials
Hello Everyone. wanted to put MT street radials on the rear of my 997.1 t.
Can you tell me, the tire is 35 vs 30 stock. so the overall diametr of the wheel will be almost .7" taller. what do I do with fronts? leave it stock?
is the transfer case will handle this fine/? will the MT tire clear the fenders? is there better drag tire for 997.1t? what is the best f+r tire setup for drag 997.1?
Old Nov 30, 2011 | 11:25 AM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
My experience with 997 TT
I have heard of messed up differentials when running differant height tires. The factory is a .7" differance from front to back. There is plenty of room under the rear fender for an even wider tire. The front tires do not spin on the track, I wouldnt worry bout DR's up front. As far as Rears go. A Toyo R888/RA1 should handle high HP as long as you know what you are doing. The R888 is noisy though.
Old Nov 30, 2011 | 11:29 AM
topspeedua's Avatar
So what you are saying, if I put the 305x35 MT drag radials in the rear, I need some taller tires to the front to match the difference?
R888 is nothing compare to MT((
Old Nov 30, 2011 | 12:44 PM
GAM3OVR's Avatar
GAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to beholdGAM3OVR is a splendid one to behold
How much power are you putting down?
Old Nov 30, 2011 | 01:52 PM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
The 305/35-19 Mickey Thompson radial II is 27.9 diameter. Too much compared to the stock factory diameter of 26.2. Your best bet is to get a set of 18 inch wheels and put the 305/30-18 on the rears and the diameter is 26.4.
For road use this tire is the best drag radial you can get. I used them on my 800+ whp GTO.
Old Nov 30, 2011 | 01:55 PM
SpoolnV8's Avatar
Yes.
Ive been 1.4-1.5 60's on Nitto Invo. MT DR is overkill I think... I actually bought a set but never installed them on my wheels since it does well on regular street tires. Ill send you a PM
Old Nov 30, 2011 | 02:05 PM
Doc GTO's Avatar
Another option is the Toyo Proxes TQ street drag radial. 315/35-18 is 26.6 diameter.
Link:
http://toyotires.com/tire/pattern/proxes-tq
Old Nov 30, 2011 | 02:07 PM
Doc GTO's Avatar
Originally Posted by SpoolnV8
Yes.
1.4 60fts is crazy! I've gone 1.52 in my GTO and that was a rush! I've done 1.2 60fts but in a Super gas door slammer Firebird when I got my NHRA 7.50 license.
Old Nov 30, 2011 | 05:10 PM
topspeedua's Avatar
Hello. How about the nitto drag tires?? they have right size?
i really want to keep 19" wheels there...
as for trackition, i need drag tires as our drag tracks are bad here! so we spin a lot!
Old Dec 1, 2011 | 04:35 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
i tried them , car did not move or run eaither !!!
do not install them
Old Dec 1, 2011 | 05:48 AM
Doc GTO's Avatar
The only one that will fit your wheels is the 345 but the diameter is over 27 inches. No go for the transfer case. You may just need to get a pair of 18 inch wheels with the correct tires for the rear at the track. A track-only setup.
Old Dec 1, 2011 | 05:58 AM
topspeedua's Avatar
Is there any unexpencive 18" wheels out there? anyoene sell them? what specs tides to I look for 18 and what specs wheels? which tire to put on 18"? MT drag radials?
Old Dec 1, 2011 | 05:59 AM
topspeedua's Avatar
do not install them
on which tires? what you mean did not move?
Old Dec 1, 2011 | 06:00 AM
Slow911TT68Tip's Avatar
Slow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really nice
That is exactly what I did. I am happy with the MT's so far. They definetely hook and the 18's are within the 4% difference threshold (Front versus Rear). I am holding 850+ WHP (we are not finished yet ).
Old Dec 1, 2011 | 06:03 AM
topspeedua's Avatar
Can i keep 19" fronts and just geat a pair of rears? what specs should i look for? anyone sell used wheels?
