Need help!!
Old Jan 4, 2012 | 07:30 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
Need help!!
Something weird is going on with my turbo. When I try to start it, it turns over for a second or two then everything dies (lights, dash, radio) literally goes dark for a second then it catches and starts. It's only been doing this the last week.
I'm not sure if this is related but the other night I think I felt my clutch slip a little in 6th when I floored it, the weird thing is I tried to replicate the slippage,
But there was nothing,no slippage, in any gear....is that normal?
Some info: 07, 15k, fvd exhaust, proto tune, battery replaced 6 months ago
Any advice is much appreciated.....
Old Jan 5, 2012 | 06:25 AM
nyamg's Avatar
i also noticed that the TPMS resets when this happens......anybody expierenced
something similar???
Old Jan 5, 2012 | 06:28 AM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
I know you replaced your battery but does it seem like it is turning over slowly? There may be a slight drain on the new battery or you may need to use a trickle charger on it between uses.
Old Jan 5, 2012 | 08:53 PM
nyamg's Avatar
I'll give the trickle charger a shot.......I also noticed that the car rolls the windows down a little bit........weird!
Old Jan 6, 2012 | 06:42 AM
jhbrennan's Avatar
Check the battery.
Old Jan 6, 2012 | 07:55 AM
raclaims's Avatar
raclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to behold
The problem is the connection between the seat and the wheel...
or the battery
Old Jan 6, 2012 | 08:07 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Check your alternator too.
Old Jan 6, 2012 | 08:08 PM
nyamg's Avatar
or the battery
very funny........i cant wait to see your 458!!!!
Old Jan 7, 2012 | 06:19 AM
Sobrut911's Avatar
Sobrut911 is infamous around these parts
The windows are supposed to do it. According to the manual they should go down a few mm. to protect the seals. I also think it helps relieve pressure in the cabin to make it easier to close the door.
Old Jan 7, 2012 | 11:37 AM
One@D2Forged's Avatar
One@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud ofOne@D2Forged has much to be proud of
Maybe a loose contact somewhere is touching the chassis and making this problem occur?
