passenger outside mirror stopped working
Old Jan 25, 2012 | 12:25 PM
bandi's Avatar
bandi is infamous around these parts
Very sudden about 2 months ago; even had my wife apply gentle pressure as I operated the control ****. Driver's side works fine. Seems like a bad motor or fuse would result in neither working. Maybe a loose connection on that side? Please help---I'd love to avoid the dealer on this one!
Old Jan 25, 2012 | 12:27 PM
jhbrennan's Avatar
Can you hear the servo trying to move?
Old Jan 25, 2012 | 12:36 PM
bandi's Avatar
On the driver side, yes, but not on the passenger side. Thanks
Old Jan 28, 2012 | 10:10 AM
rbservice's Avatar
rbservice is infamous around these parts
Bandi, I had a similar problem with my driver side mirror. Took it to the dealer and they found nothing. Everytime I closed my door the mirror had to be re-adjusted when I got back in. By accident I fixed it myself! I set the drivers seat memory, which I had not done previously, and it was magically repaired. Don't know if you have tried that, but give it a shot.
Old Mar 1, 2017 | 04:31 PM
bgrpph's Avatar
bgrpph has a spectacular aura aboutbgrpph has a spectacular aura aboutbgrpph has a spectacular aura about
old post- this fixed my passenger mirror issue. Using the memory button fixed issue i was having with passenger side mirror not responding to the mirror control switch- while drivers side worked fine.
I pushed the memory buttons 1 & 2- my passenger mirror moved to the preset setting. - after using memory buttons- the mirror switch on drivers door worked normally again moving the passenger mirror-
pshep138
Sep 1, 2015 09:45 AM
rnl
Aug 26, 2015 02:36 PM
Zero911
Aug 24, 2015 06:51 PM
ppwchiang
Aug 20, 2015 10:28 AM
saline
Aug 19, 2015 12:25 PM
