Possible new standalone ECU for 997tt
Old Feb 20, 2012 | 10:33 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Here is a list of features Syvecs has on their website.
It has the ability to do the job of the factory ECU and a hell of alot more!!!
For example it will control the VTG's, Variocams, etc...etc...
ECU Hardware
RISC CPU
8 Ignition Coil outputs
16 Fuel injector outputs
24 general purpose inputs
4 Knock inputs
2 NTK wide band Lambda interfaces
2 K-type thermocouple interfaces
100 MHz full duplex Ethernet for connection to PC for programming and data download
2 Can 2.0B interfaces
RS232 serial interface
6 to 26v input voltage range with reverse polarity protection
2 regulated 5V sensor supply outputs with protection
Software configurable sensor (5v to 12v) sensor supply output
Unregulated sensor supply output which tracks the ECU supply voltage
5 Separately protected sensor and communication ground inputs
4MB or 8MB memory
88 pin automotive connector
Anodised aluminium case
Dimensions 178 x 122 x 36 mm
Main features at a glance
(for full features list, see software tab)
4 Individual Ignition and Fuel maps
Fully sequential control of fueling and timing.
Batch firing and wasted spark ignition.
Individual cylinder TDC definition
Idle control, closed or open loop
Cam control, closed or open loop, up to 4 camshafts.
Rpm limit : 20000 RPM
Fully configurable Data logging with individual choice of logging channels and frequencies.
Fully mappable Wastegate control, with gear dependent boost maps.
Launch Control - Retard and Fuel cut strategies.
Traction control - Fully programmable slip targets.
Drive by wire
Knock control - Fully Mappable
Full throttle shift cut - Open and closed loop, full programmable
Anti lag - 4 ALS Calibrations, EGT dependency, Jacked open throttle idle control, ALS Initiation strategy.
Full 3D mappable Nitrous control, Wet and dry systems.
Crankshaft/Cam Signal Oscilloscope with sync loss capture
User Programmablelinearization of all sensor inputs.
Battery Voltage compensations
Upgradeable firmware
CAN Bus interface
Configurable I/O
Hall & VR Crank/Cam sensor compatible
They would like to use my car as a donor.
What do you guys think?
Old Feb 20, 2012 | 10:55 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Is that a piggyback or true stand alone OEM ECU taken out?
Depends on the cost, ProEFI and MoTec come to mind as know piggyback solutions.
Old Feb 20, 2012 | 12:16 PM
GTRNICK's Avatar
It is a true stand alone ecu.
Old Feb 20, 2012 | 01:48 PM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Is it Syvecs ECU?
http://www.syvecs.com/s8c.php
How do you plan to run ABS, PSM, PASM etc.. ?
I think it's better to use ProEFI, i have one in stock if you are interested.
Old Feb 20, 2012 | 03:04 PM
GTRNICK's Avatar
Originally Posted by Emre@Esmotor
Is it Syvecs ECU?
Yes it is the syvecs.
This is questions that they will have to answer, but they did say what ever the stock ECU will do the syvecs will do better or just as good.
Why do you reccommend ProEFI over Syvecs?
What I would like to know is what is the advantage of running one of these Ecu's when the 997tt ecu is open?
Is it because not everyone has the knowledge or the correct files to write to the 997 Ecu?
I heard there is an advantage for a race car but thats about it?
Old Feb 20, 2012 | 04:23 PM
mozhacker's Avatar
mozhacker is infamous around these parts
20k rpm limit? I'm assuming an engine would melt far before it got that high, so basically this setting means no over-rev protection right?
Old Feb 20, 2012 | 04:38 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
capable of having 20k RPM limiter not ONLY 20k Limiter is what it means.. You can set the limiter anywhere you like..
There are plenty of good options for stand alone ecu tuning.. They all cost a decent amount $$$ thats all..
Mike
Old Feb 22, 2012 | 06:54 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Are there fully programmable PWM'd outputs ( and inputs too ), preferably with closed loop capability in relation to MAP & RPM? If not, you're not going to be able to control VGT turbos.
Old Feb 22, 2012 | 09:20 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Hey Nick...if you're planning to continue running VTG's, what would be the benefit of the standalone unit? The factory ECU is well capable of being tuned for any VTG setup. Why take a chance?
Personally, I wouldn't do it, unless you switch to a non-VTG setup..then it could sound interesting. But even then, there are plenty of other tried and true options for non-VTG cars, like the ProEFI that Emre offered.
Old Feb 25, 2012 | 04:18 AM
Miguel-H's Avatar
Miguel-H is infamous around these parts
There are a great many advantages to running a Syvecs (or any other standalone) over a Rom-flash. Admittedly a little overkill for those owners that just want some quick bolt on additions, but when pushing the boundaries having something like low oil pressure or fuel pressure safety trips to protect your investment makes savvy sense to me. Why spend thousands on your P&J engine to then make compromises on management? What Nick has listed is just a fraction of what the unit is capable of. Ryan @ Syvecs would be the man to cover this topic in more detail and he would be more than willing to answer any questions you may have, nice guy too.
Old Dec 16, 2012 | 07:02 PM
Boyan Radomirov's Avatar
Boyan Radomirov is infamous around these parts
Hi,
im sorry to barge in and start posting. Most all of you dont know me. I would like to shed some light on this as there is much misconception floating around .
I have been working on this project prior to Syvecs being involved. We were looking for full integration ECU as there are some limitations with running piggyback. Syvecs and Switzer made this possible as Syvecs provided the hardware and some of the framework and Switzer provided the data needed to run the auxiliary functions.
Ryan can elaborate on this as also few users that have been selected to run the debugging. Currently the 996 kit is in reproduction stage and will be installed onsite at Syvecs UK or Syvecs US. There is nothing publicly available for the 997. (but its being worked on).
Old Dec 17, 2012 | 01:48 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Hi Nick,
I wouldn't go.
I have really little time for leisure, so
I only run well known solutions, in the past I tried some "standalone" mods on other cars or bikes, the best way to go from passion to nightmare...
Now if you have plenty of time and like beeing a " pionneer"...
dhahlen
Nov 5, 2015 12:55 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
