trying to decide between sachs 2.5 vs clutchmasters stg1 clutch/pp kit?
I only have experience with the Sachs 2.5 kit.
The clutch engagement is almost like stock, except it grabs a little quicker now. Pedal effort is exactly like stock. I think if I didn't tell you, you couldn't tell there's a aftermarket clutch in there unless you're paying really close attention. It holds the power nicely too, I have exhaust and tune on the car.
The Sachs 2.5 kit will not hold up to 900whp. The 764 pressure plate is rated only up to 900nm of TQ, which is equal to about 550 lb/ft. Beyond that you'll need something else.
Hello Tom - torque at wheel or at the crank?
This page comes from cannga, who copied it from the Sachs website. I'm not sure if we're translation whp/torque at the wheels versus at the flywheel - not even sure if it matters as clamping force is dependent on the torque generated. It reports 659 lb/ft torque clamping force?
In our experience, testing on both 997 Turbos and 997 GT2's, the 764 starts slipping exactly where Sachs says it will...right around 550-560 at the wheels. That sort of confirmed my suspicion that their rating is a crank number. Beyond that power level, you're on thin ice with this clutch IMHO.
We are using it with big GT30/Alpha30 kits on HIGH boost ( 28-29psi ) in many cars for a years with great success.
WheelB
Lamborghini
Aug 20, 2015 12:25 PM
