DIY Oil Change, 2010+ DFI 3.8L Turbocharged Engine, M97 9A1
Old Jun 16, 2012 | 06:22 PM
bbywu's Avatar
Oil drain plug M18 X 1.5, replace sealing ring, 37 ft/lb
Oil filter cover, replace gasket, 19 ft/lb
Oil volume during oil change 7.5L
Oil volume during new engine build 10.4L
1. Pull out telescopic oil filler tube
2. Clean filler tube with clean cloth
3. Loosen oil filter cover counter clockwise
Once you have the engine bay ready, lift the car appropriately. Either jacks and jack stands, or appropriate gradient ramps with wheel chocks. Once lifted and secured, slide under the rear of your car and proceed with the following steps:
4. Unscrew oil drain plug, hexagon socket - NOTE THIS IS A HEXAGON NOT TORX INSERT, AND THE BOLT IS VERY SOFT (ALUMINUM.) YOU MAY WANT TO SWAP TO STAINLESS STEEL.
5. Drain oil
6. Replace sealing ring
7. After replacing engine oil, replace oil drain plug 37 ft/lb
8. Losen oil filter cover with AF36 (or equivalent) tool.
9. Remove filter cover, remove gasket, pull out filter element.
10. Fit new gasket, replace new filter element.
11. Replace filter and cover into oil filter housing.
12. Hand tighten cover, then torque to 19 ft/lb.
13. Replace engine oil, 7.4L for oil change, 10.4L for engine rebuild/new engine.
Old Jun 16, 2012 | 06:31 PM
bbywu's Avatar
Pics added, OP updated and annotated.
Old Jun 16, 2012 | 06:52 PM
bbywu's Avatar
Also note, the plastic cap on the fill tube can snap off. It can be unclipped and replaced.
Old Jun 17, 2012 | 02:20 AM
TT Chris's Avatar
TT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud of
Thank you so much Bob. You're a lifesaver and don't know how you found a DIY already.
Old Jun 17, 2012 | 02:36 AM
TT Chris's Avatar
Hey Bob,
If I can add the part #'s below that are needed for the oil change. I confirmed the parts twice with my local Porsche dealer. Once I do the oil change this weekend I will know if they gave me the right parts or not.
900-123-106-30
948-107-222-00
948-107-322-00
900-123-010-20
Old Jun 17, 2012 | 06:46 AM
bbywu's Avatar
Good luck, the instructions I listed above come from Porsche's technical documents. Part numbers are always good - thanks.
Can you remind me what size hex insert/Allen you used? I couldn't remember if it was a 22 or 23mm.
bob
Old Jun 17, 2012 | 09:05 AM
bbywu's Avatar
Part number for oil cap if you snap it off by mistake (like me): A91 107 035 01
Old Apr 16, 2018 | 10:39 PM
Big Swole's Avatar
Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !Big Swole Is a GOD !
Sub'd for future if needed. Thanks
Old Jul 21, 2019 | 09:56 PM
babypimpin's Avatar
babypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to beholdbabypimpin is a splendid one to behold
Hey guys,
Sorry to bring up an old thread. But I just picked up a 997.2 turbo a couple weeks back and this is my first (and hopefully not my last) porsche.
Looking to do an oil change and came across this thread. Not many DIY's for the 997.2 turbo's which sucks, so i've brought this one back from the dead.
Going back to TTChris's post in post 5 above (https://www.6speedonline.com/forums/...ml#post3570265), he's mentioned that we need all of these parts for the oil change.
900-123-106-30
948-107-222-00
948-107-322-00
900-123-010-20
I've aded them all in the cart at pelican parts and looking to put the order in.
However, just wanted to clarify and confirm a few things.
The green o-ring for oil filter cover. I don't actually need to buy this separately correct? It appears the filter already comes with one?
Also, do I need both the aluminum crush washer AND the copper washer? or are those meant to be for the same application? If I need both, I believe the aluminium crush washer is for the drain bolt. But where does the copper one go?
Any clarification would be helpful.
Thanks!
Old Jul 22, 2019 | 12:35 PM
Big Swole's Avatar
I've not done mine yet on my own but have ordered filter kits from Suncoast.
Seems if I remember, it had the filter, large O-ring, small O-ring, and ONE aluminum washer. No copper washer.
Old Jul 22, 2019 | 06:33 PM
Darth-Jesus's Avatar
Darth-Jesus is infamous around these parts
The o-ring did not come with the filter on my last order. I had to order separate - (I ordered thru Sonnen)
Also - I think the copper washer is an error. Not sure where that would go with just an oil change. The other parts all are correct.
Old Jul 22, 2019 | 09:02 PM
babypimpin's Avatar
Yah I can't seem to think where the copper washer would go.
I'm going to go ahead and order the filter kit which should include the rubber o ring/gasket for the oil filter cover. Will pass on buying these extra o ring gaskets.
Ill grab a few of the aluminum crush washers as those are cheap and may not come with the kit.
And then not bother with the copper washer.
Old Jul 24, 2019 | 02:33 AM
atm4jim's Avatar
atm4jim is infamous around these parts
The copper washer is for 997.1 dry sump oil reservoir and I think doesn't apply to 997.2.
Old Jul 17, 2021 | 10:30 AM
2fast2nick's Avatar
2fast2nick is infamous around these parts
Thanks for this post! Just did mine, so easy.
Old Oct 7, 2021 | 01:06 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
By any chance anyone come across a video to supplement this great guide?
1Gunner
Dec 17, 2021 07:30 PM
gnat
Cayenne 958
92
Dec 16, 2020 04:25 AM
iambon
Oct 10, 2015 10:16 PM
jjlawyer
Aug 22, 2012 12:35 PM
Jnocerin
Jul 11, 2009 05:40 AM
