Brake Pads
Old Jul 5, 2012 | 03:31 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Brake Pads
Has anyone found a better than oem brake pad for the track that still offers acceptable street performance - as in little to no squealing? Thanks,
Old Jul 5, 2012 | 05:12 PM
vividracing's Avatar
Pagid RS29 Yellow is what I recommend.
Old Jul 5, 2012 | 05:42 PM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
The Pagid RS29 sound like a pig in a slaughterhouse.
Old Jul 5, 2012 | 05:53 PM
No that would be the RS19. If bed in properly the RS29 yellow are excellent.
Old Jul 5, 2012 | 05:59 PM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
Hawk DTC-60s or 70s. I just got back from VIR north course in 117 degree heat index with zero brake issues. I also use ProSpeed 683 fluid.
Old Jul 5, 2012 | 06:12 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
so when you run these bads you should run prospeed 683 fluid ? or its ok to remain useing oem break fluid ?
Old Jul 5, 2012 | 06:13 PM
w00zy's Avatar
Mine squeal a lot in the stop and go traffic, with light braking. I need to brake hard 2 or 3 times to make the squealing go away.
I like how they perform and i would also recommend them over the stock pads.
Old Jul 5, 2012 | 06:21 PM
w00zy's Avatar
A better brake fluid with higher boiling temperature is always recommended. Also some stainless steel braided brake lines.
I use Castrol SRF and Goodridge brake lines
Old Jul 5, 2012 | 06:27 PM
ysfg35's Avatar
ok if you do not mind , could you tell whats the serial number for the castrol SRF , as there are many !!!! which one you are using ?
plus how do you compare goodridge brake lines with other kinds ??
Old Jul 5, 2012 | 06:37 PM
w00zy's Avatar
Didn't know that there was more than one. I buy from a local shop. Castrol React SRF Racing
Don't know. I bought what was available. The important thing is that they are stainless steel braided lines
Old Jul 5, 2012 | 06:46 PM
ysfg35's Avatar
thanks for your information buddy
rep for you ..
Old Jul 5, 2012 | 07:00 PM
w00zy's Avatar
rep for you ..
Thanks. Glad to help
Add front and rear 2 piece floating rotors to reduce unsprung weight and you will have the best upgrade for the stock callipers
Old Jul 5, 2012 | 07:08 PM
ysfg35's Avatar
thanks for the advise ,
well to be honest am not track guy , i drive my car as DD and i like the stock brake pads , rotors !! but since am running 825hp package and i like inline street races its good to upgrade the susp and brake system , so am doing it step by step , as the susp i did eibach lowering kit and the car felt more steady in high speed , as well as i did 20mm spacers for the rear wheels only since am running 30/295 tires it will be good and not harm the dif
now for the brake system i may do the pads still not sure which one to get , brake lines and brake fluid !!!
i would like to keep my car DD and not hard to drive
Old Jul 5, 2012 | 07:22 PM
w00zy's Avatar
With the 2 piece rotors you reduce more than 1Kg per rotor. Good for any type of racing
Old Jul 5, 2012 | 07:24 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Agreed You have to remove the squeal shims or the pads won't fit. These suckers squeal like a banshee and shed brake dust like crazy. Unfortunate consequences of better initial bite and fade resistance.
If your just running street races/drags, I'd stick with the OEM pads. They're perfectly fine for that.
