Hose clamps popping off. Need to upgrade
Old Jul 23, 2012 | 09:44 AM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
After upgrading to 65mm billet wheels and GIAC tune, I have been popping off the intercooler hose that goes from the turbo to the intercooler. Has anyone experimented with aircraft style clamps or t-bolt?
Old Jul 23, 2012 | 09:48 AM
bbywu's Avatar
AWE uses clamps similar to these:
Old Jul 23, 2012 | 02:17 PM
OneFastBeast's Avatar
OneFastBeast is infamous around these parts
Call bbi they got high grade hose clams. No problem since!
Old Jul 23, 2012 | 06:31 PM
Forujames's Avatar
Forujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to allForujames is a name known to all
I have a Champion car (2008) with mods similar to yours-how do you know when the hose pops off? sound, performance, or do you have to check for it.
Old Jul 23, 2012 | 07:58 PM
higb987's Avatar
higb987 is infamous around these parts
any hydraulic supply house nearby should have t-bolt clamps. You can also use hairspray as your lubricant to slip the hose on. When the alcohol in the hairspray evaporates the sticky from the hairspray will keep that sucker on.
Old Jul 23, 2012 | 08:00 PM
higb987's Avatar
there is usually no doubt about it. sometimes it sounds like a lout popping. then the car will go limp and could start stalling. depending on the hose you might get immediate check engine lights.
Old Jul 23, 2012 | 08:31 PM
Forujames's Avatar
thanks. js
Old Jul 24, 2012 | 06:09 AM
PacMan Z's Avatar
It sounded like a shotgun went off or a big turbo supra
Old Jul 24, 2012 | 09:19 AM
Mike12345's Avatar
Mike12345 is infamous around these parts
Can you get two ordinary hose clamps seated properly on there? Oppose the worm gear housings. I'm guessing that would probably do it.
alwaysbored786
Apr 19, 2016 05:51 AM
shifter_
Sep 8, 2015 12:07 PM
The Oss
Aug 24, 2015 08:19 PM
magoochi
Aug 23, 2015 05:54 PM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
