Small leak found on PPI - should I worry
Old Oct 26, 2012 | 02:21 PM
mbr129's Avatar
mbr129 is infamous around these parts
The dealer mechanic that has serviced this car has it wasn't a big deal, and probably a hose, but what do you think?
It has over 80k miles, but everything else checked out great and the mechanic knows the car and said it's a good car.
Thanks guys.
Old Oct 26, 2012 | 02:33 PM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
Cars break. Its a fact of life.
In my opinion, if the price of the car reflects any repair that is needed, then I say get what you want.
If you are worried because upkeep of such an expensive car will leave you with no funds, then I would pass and reconsider.
Mike
Old Oct 26, 2012 | 02:40 PM
mbr129's Avatar
Mike
That's not the point. I am buying the car, and if the repair is considerable (I dunno, $500+) I should get that knocked off the price.
Just curious if you guys have seen this kind of leak before. The mechanic basically said he wouldn't do anything abotu it since it's so minor, bt after thinking about it, not knowing the source kinda bothers me. It seems pretty clear it is not the block.
Old Oct 26, 2012 | 03:01 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
I am sorry but that looks like a pretty major leak to me. Let me put it this way, Porsche's were traditionally air cooled aided by having huge amounts of oil in them. Combine that with Porsche's racing heritage and the incredible difficulty for mechanics to service the engine in race situations, Porsche has spent huge amounts making sure there are not oil seepage or leaks. For these very reasons, if you see oil anywhere around engine components of a Porsche, you should be worried.
My 2Cents.
Cheers.
Old Oct 26, 2012 | 03:05 PM
mbr129's Avatar
Fair enough. Thanks.
Old Oct 26, 2012 | 03:11 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
My 2Cents.
Cheers.
Agreed^. That does seem pretty major as well as it looks like it's been leaking for a while.
Edwin
Old Oct 26, 2012 | 03:16 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Get a root cause for the leak before you do anything and from there you can determine if in fact it is minor, although it does not look like it.
Old Oct 26, 2012 | 03:18 PM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Interchangeable parts my friend... I say pull the turbos and make sure all the seals and lines are connected. I say pull the trigger ; find a good tech to fix her up!
Old Oct 26, 2012 | 03:21 PM
gmoney's Avatar
it looks major but I bet thats a slow leak over time right there. I would not worry about it.
Old Oct 26, 2012 | 03:38 PM
bbywu's Avatar
Mechanic says he knows the car and its a good car, and it's just a hose.
Do you still trust the technician's inspection of the rest of the vehicle?
Old Oct 26, 2012 | 03:40 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
For the most part as long as it did not run dry and damage anything............
A man built is and the RIGHT man can fix it.
Buy it and drive it like you stole it...................................
Old Oct 26, 2012 | 05:22 PM
L_Perm's Avatar
L_Perm is infamous around these partsL_Perm is infamous around these parts
That looks like a leaking seal around the cam housing, which I believe would require an engine drop for repair. It doesn't look like anything that would cause damage as long as the previous owner kept track of oil level.
LP
Old Oct 26, 2012 | 05:42 PM
mbr129's Avatar
Well, it's not a big leak, otherwise it would be leaking more than nothing over many hours. Also, the car was checked right after the guy drove it to work, which is 1.5 hours of hwy driving (which explains the mileage), so it was plenty warm.
It did not seem to be leaking from the engine itself. It was just that small section to the left of the car. The tech words were basically, "well it's an 80k mile car and that's pretty minor." It was more of an attitude of "it's not really an issue now. Fix it when it does become an issue."
I am in fact getting a hell of a deal on an otherwise pretty clean car.
I've asked the owner (co-worker who bought it with 38k miles 3 years ago) to have it cleaned and have the source of the leak diagnosed.
Thanks for the feedback.
Old Oct 27, 2012 | 11:31 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
I think its leaking through one of those hex bolts on the housing. I had similar leak when my car had 3k miles (bogger had same problem too), actually one of those bolts were lose and I could screw it off with my fingers. I would say clean up the area and retorque those bolts, I think they only need 7 ft/lbs of torque, and see if it still leaks.
Old Oct 30, 2012 | 09:58 AM
mbr129's Avatar
Seller dropped off car at the dealer to have the source of the leak identified. He said he has never seen a drop of oil in the garage. Regardless, he wants to know the source too.
If it checks out to not be be a big deal, I will buy the car. It looks like a 25k-mile car in and out and drives well.
If it needs to have the engine dropped and major service/maintenance done soon (plugs, clutch, etc) then so be it. I am getting it for a pretty good deal, and once that all gets done it should be good for a few years considering I will only put 5k miles a year.
