Question for Manual 997TT owners....
Old Jan 28, 2013 | 10:52 AM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
Yesterday, while doing some spirited driving, i had a mis-shift. I wanted to go from gear 3 to 4 but while completing the shift, it didn't follow through. It went into neutral and I stepped on the throttle. The engine revved to 7000-7400 rpm's. I wasn't sure if it was a stage 4 overrev, so called my friends in a local garage and immediately went to read my DME. God's grace no overrev's in range 4. It happened today as well and i am sure it bounced off 7200-7400 again.
Since i am new to the car, the mechanical feel of the short shifter is a little different from the BMW Z4//M i used to drive. Will take some getting used to.I am sure because of yesterday's incident, it wouldn't be anything. My question is, is there a rev limiter that doesn't allow the engine to go into a stage 4 over rev or something like that? I asked my tech what is the over rev range for each gear and he wasn't sure. I see various posts regarding the ranges for each number but can someone tell me exactly what are the over rev ranges? Will accidentally shifting into neutral cause the engine to protect itself by some sort of rev limiter despite throttle input?
Newbie here, so please share your opinions. Any help appreciated.
Thanks,
Mathew
Old Jan 28, 2013 | 11:07 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
I would sell it before your engine explodes.... you probably hurt it doing that and its only a matter of time now especially since its is not the metzger engine that you have.
Old Jan 28, 2013 | 11:22 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
^^ . He has an '09.
To the OP...you'll be fine. Typically range 4 and 5 will happen due to some kind of mechanical over-rev. For example, if you shift from 5th down to 2nd instead of 4th...at a high speed. If you just floored the throttle in neutral the engine has a rev limiter which will stop rpm's before you can cause any damage. I wouldn't worry about it..
Old Jan 28, 2013 | 11:28 AM
bbywu's Avatar
Originally Posted by Tom@Champion
^^ . He has an '09.
Some folks are experts. Others are expertz.
Old Jan 28, 2013 | 11:31 AM
haha good one!
Old Jan 28, 2013 | 11:32 AM
bbywu's Avatar
Thanks,
Mathew
When you accelerate by stepping on the gas, there is a fuel shut off just after to redline. On a 6 speed, redline is 6750 RPM on gears 1-5, and 6800 RPM 6th gear. Fuel shut off is 7000 RPM in all gears. Engine velocity and momentum will cause the revs to climb momentarily - but it is limited.
When you shift 3 to 2 inappropriately, no fuel shut off will save your engine.
Old Jan 28, 2013 | 11:42 AM
To the OP...you'll be fine. Typically range 4 and 5 will happen due to some kind of mechanical over-rev. I wouldn't worry about it..
Thanks Tom
thanks bbywu! So if the rev counter needle goes all the way to 7400 during my accidental neutral shift, it would be just a visual display on the rev counter?
Also picked up rev ranges for 997TT on another forum:
Range 1- 6800-7000
Range 2- 7000-7200
Range 3- 7200-7400
Range 4- 7400-7900
Range 5- 7900-9000
Range 6- 9000++
Is this correct?
Old Jan 28, 2013 | 11:47 AM
bbywu's Avatar
The needle on the tachometer does not 100% correspond with actual engine speed.
Old Jan 28, 2013 | 11:48 AM
So in your experience, is it slower?
Old Jan 28, 2013 | 11:49 AM
bbywu's Avatar
Looks like your info is correct.
Old Jan 28, 2013 | 11:56 AM
thanks a lot!
Old Jan 28, 2013 | 12:24 PM
kosmo69's Avatar
kosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nice
just like the temp gauge!
Old Jan 28, 2013 | 01:19 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
FWIW, I got a few Range 4s just by bouncing off the stock rev limiter at WOT. I do have a tune on my car, but the stock redline was retained.
Old Jan 28, 2013 | 01:20 PM
jhbrennan's Avatar
Hans might explode if you don't spell his last name correctly,
Old Jan 28, 2013 | 02:16 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Glad this got settled. You will be fine, just stay away from 5 to 2 downshifts. That be bad :-)
