Anyone come across this before????
Old Feb 4, 2013 | 01:52 AM
0zzy997's Avatar
0zzy997 is infamous around these parts
Hi guys,,
Few days ago I had a stage one tune from a reputable source here in U.K. Gains of 50-60 bhp and 100 tq .
Although I've got lots more power which I'm really happy with. The problem is every time I start my car the revs hold at 2000rpm, I then need to turn engine off and restart then all is well...... This didn't used to happen before the tune.
Rang the tuning company he said they will send someone out to do some tweaks to my car.
What I want to know off you guys is. Is this normal?? Should I let them tweak the map?? Or should I just tell them to remove the tune and go with another company??
Regards
Old Feb 4, 2013 | 02:18 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello,
Its not normal.
What parts do you have on your car?
Regards,
Emre
Old Feb 4, 2013 | 02:27 AM
0zzy997's Avatar
My car is stock. Never had anything done to it.
What I meant by normal was. Is it normal where they have to twak the map again??
Thanks for quick reply .
Old Feb 4, 2013 | 02:35 AM
Normally there shouldn't be any more tweak related with Idle on a completely stock car.
This happened just after the software re-map ?
Old Feb 4, 2013 | 06:18 AM
0zzy997's Avatar
Yes straight after tune.
Now they've put a different map on it. And its still causing the same problem.
Also after the second map at idle car is idling at 800rpm. Think they have lowered initial idle speed altogether.
Old Feb 4, 2013 | 06:19 AM
Still not normal.
There is no need to play with Idle settings.
Old Feb 4, 2013 | 08:50 AM
0zzy997's Avatar
Its just weird its happend soon as its been mapped. Any ideas what it could be? Might just tell them to put back to stock an I'll find another company to do my tune.
Old Feb 4, 2013 | 09:41 AM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
That's what i would do
Old Feb 4, 2013 | 10:06 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Go back to stock, I bet the way they get the power is by leaning out the car which is not good for the motor at all. Go back to stock and go with a reputable tuner that knows what they are doing. GIAC, TPC Racing, etc. etc.
Good luck.
Old Feb 4, 2013 | 10:36 AM
I can tune your car remotely over email, let me know if you need anything.
Old Feb 5, 2013 | 12:15 AM
CrazyMD's Avatar
CrazyMD is infamous around these partsCrazyMD is infamous around these parts
Put it back to stock, get softronic tune and you can do it from your house
Old Feb 5, 2013 | 01:13 AM
blackbull's Avatar
blackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond repute
Could be a vacuum leak.
Old Feb 5, 2013 | 05:41 AM
0zzy997's Avatar
I doubt its a vacum leak seeing as the problem started from first start up after tune,
It only sticks at 2000rpm on cold start. On warm start its fine.
I've had them put stock map on, just waiting for few hours to let engine cool down so I can test it.
Regards
