What HP is 997.1 stock fuel system good to?
Old Apr 10, 2013 | 09:00 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
And, can I do just exhaust, intercoolers, and 65 billet VTG Turbos? What other mods are needed?
Old Apr 10, 2013 | 09:53 PM
greekc6's Avatar
Subscribing
Old Apr 11, 2013 | 01:50 AM
G911's Avatar
G911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of lightG911 is a glorious beacon of light
+1 sub
Old Apr 11, 2013 | 02:04 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
I was running GT3076 turbos , after 1.6bar the duty cycle of the injectors were 98% !!!! , so i jumped to 80lb injectors !
I think with VTGs you will be fine running stock injectors
Old Apr 11, 2013 | 02:09 AM
G911's Avatar
And, can I do just exhaust, intercoolers, and 65 billit VTG Turbos? What other mods are needed?
Witch VTG you want to bye?
Old Apr 11, 2013 | 02:28 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
You don't need new injectors or fuel system upgrade with VTG turbos and stock engine.
Old Apr 11, 2013 | 09:07 AM
Not sure yet. I like the price of the AWD 65mm. I like the performance of the champion, but dont like the price.
Old Apr 11, 2013 | 11:08 AM
Stroker's Avatar
Stroker is infamous around these parts
Originally Posted by Tony@epl
I disagree. The fuel system it self is fine, however we still recommend doing a larger injectors.
Hi, could you explain why and from which power level?
Regards
Old Apr 11, 2013 | 11:01 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
When I had my 63.5 vtgs and tune, I was surprised to find that when I looked at the duty cycle, it maxed out at times. Personally, I would switch them to be safe if you're running full tilt on built 65s.
Old Apr 11, 2013 | 11:23 PM
Ok, so:
injectors
intercoolers
exhaust
plugs
65 vtgs
tune
Thats everything needed?
Old Apr 11, 2013 | 11:30 PM
TTdude's Avatar
If you have a 6speed, you'll eventually will have to upgrade your clutch.
Old Apr 12, 2013 | 12:03 AM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Ok, so:
injectors
intercoolers
exhaust
plugs
65 vtgs
tune
lots of $
Old Apr 12, 2013 | 07:16 AM
Chkmgnt59's Avatar
Chkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud of
From conversations with ToddK:
93oct - stock system good up to 65vtgs, then just put in 80# injectors and good until you go crazy with built engine and 800+whp
E85 - stock system good on stock turbos, then 80# injectors for any size VTG. Alpha or GTX turbos might require major rework of fuel system depending on your final goal.
Old Apr 12, 2013 | 11:15 AM
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
We have tuned a couple 68mm VTG cars on the stock fuel system. On our dyno, the limit for petrol fuel was right around 530-550 wheel utilizing the stock FPR. Keep in mind we utilize a Mustang Dyno, so if you are comparing to other units this limit can be considered much higher.
The LPFP setup is very good, so your headroom will be significantly raised with upgraded injectors.
A VTG upgrade like Champion has some serious headroom, and you will run into hardware restrictions well before reaching the limits of the turbo. To take full advantage, you want a good set of intercoolers (997.2 becomes restrictive at that power level, we recommend Champion or AWE), inlet pipes, 3.0-3.5" exhaust and injectors. If you need help getting setup to make the most out of your build, feel free to PM me.
Old Apr 12, 2013 | 01:17 PM
Stroker's Avatar
Which injectors would you recommend?
THX
