Power Kits? What works and is not overated?
Old May 11, 2013 | 11:46 AM
  #121
cannga's Avatar
Originally Posted by stef@europipe
The point of measurement is between the turbocharger and the cat. All the 993 Turbo, 996 Turbo and the 997 Turbo stock exhausts have an extra bung to measure the backpressure. So the position of measurement is the same for everyone, the stock engine is the same too and I run my car with the sport chrono button activated. I've measured the backpressure during different weather conditions, while freezing and at 25°C and the results were identical. What other variations have I overlooked?
For your purpose of comparing a simplistic single value within the Europipe family of exhausts you have not missed anything. It *would* be nice to see a more sophisticated graph against rpm on x axis, overlaid on boost, etc. And of course, the bottom line, the dyno. What is your dyno's difference when you go from 4 psi to 2 psi, is there a diminishing return at some point? Is there loss of torque at earlier rpm?
As stated above, my question has not been about whether your measurement is accurate, but whether it is a valid number that could be interpreted across different cars and manufacturers. In other words, for example, could we use your measurement against the measurement of say Akrapovic? Is this variation why Akrapovic, FVD, Cargraphic, etc., make NO mentioning of this simple back pressure measurement? These are really questions and I am not being sarcastic at all.
BTW, followed is another person's opinion, I don't know who on earth "Tuner University" is , but I believe a similar point to what Tom wrote previously, and my question, is stated:
http://www.tuneruniversity.<wbr>com/blog/2012/08/how-to-<wbr>measure-exhaust-backpressure-<wbr>for-smarter-exhaust-upgrades/
Most exhaust systems are going to be in the upper 8-10psi range under full load. A decent aftermarket exhaust will peak out at around 4-5psi with some of the very large ones peaking around 1-2psi, though, once you get lower than 4 or 5psi, it’s kind of a diminishing returns kinda thing.It’s going to depend though on the car, the exhaust design, if there’s a turbo or not, and a number of other factors. The measurements are more comparative (ie, they are useful against themselves not necessarily against other people’s measurements) than anything.
Old May 11, 2013 | 12:23 PM
  #122
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
If you have two different exhausts - using the same tune, under the same conditions, just plot the load vs rpm. You can do this with virtually any component to see if it makes difference.
Old May 11, 2013 | 02:21 PM
  #123
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
I don't go from 4 psi to 2 psi. I go from 6.4 psi (stock exhaust) to 2.6 psi (stage 1) and to 1.75 psi (stage 2).
I gain hp and tq from down low to redline with both systems.
My answer is yes.
Yes you can.
That is an assumption. I don't know why they don't, please ask them.
I apologize to elite1 for ruining this thread.
Old May 12, 2013 | 10:47 AM
  #124
cannga's Avatar
Stef, not to worry, clearly I am the rude transgressor here, you are merely answering; and what's more interesting, 1 of 200,000 "which tuner is better" threads that's 2 pages from being locked , or back pressure and dyno? Kidding aside, elite1 pls pm as needed if this bothers you. And Stef you really don't have to answer if you don't like to; as obvious from my Bilstein thread, I am quite capable of carrying a monologue, by myself of course :-).
Re. back pressure, thanks for the clarification. Between stage 1 and and 2, the difference in back pressure is 0.85 psi at redline? I assume it's responsible for the hp gained between your EP stage 1 and 2?
Stage 1 exhaust
minimum + 18 hp
Stage 2 exhaust
minimum + 20 hp
Does the above mean you have run dyno's and notice a 2 hp difference from stage 1 to stage 2 on the dyno, without a re-tune?
It would be interesting to see the 2 dyno's of the 2 stages, where peak hp occurs on each, where difference occurs, etc. 2 hp is so insignificant and actually less than dyno variation? Sorry for all these questions or if I guess wrong, this is why I have been asking if you have the dyno's (at different back pressures as you mentioned) to share.
Old May 13, 2013 | 02:06 PM
  #125
That is correct. 2.6 psi - 1.75 psi = 0.85 psi. Are you pulling my leg?
With our EP1 I see gains of up to 32 hp at around 6000 rpm over the stock exhaust with a stock ECU. The EP2 is slighly better at the top but the torque gains down low and at midrange are bigger. We use Bosch and Maha dynos, the Bosch is nice but with the Maha the torque comes in earlier. I don't share dyno sheets though, besides we don't claim big power gains on our website, I'm fine with underrated results.
The downside of all the dyno tests is that they're measured at wide open throttle while most of our driving is at part throttle.
So dyno resuts are just part of the equation.
Cheers
Old May 14, 2013 | 11:25 AM
  #126
cannga's Avatar
Thanks Stef for taking time to answer.
The 0.85 psi difference is measured at red line right? How about at lower rpm's - is there a rpm below which there is no difference in back pressure between Stage 1 and Stage 2?
In some videos of back pressure measurements, the exhaust flow pulses make the needle pulsate. Do you see same degree of pulsation in your measurement?
Old May 14, 2013 | 11:09 PM
  #127
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Cheers
Weakness of a stock Porsche is the exhaust. The sound of my EP2 is worth a -20 HP in my opinion at 500HP. I like facts of a Dyno but, I would figure out how to properly demonstrate the correct sound of the EP2 on you tube. (If that’s even possible.) It’s much better sounding in person FOR SURE!
Old May 15, 2013 | 01:12 PM
  #128
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Anybody with EP in South Florida?
Old May 15, 2013 | 01:33 PM
  #129
Between 6500 rpm and redline.
Yes at idle
That is a worthless test, you have to load the engine to measure the backpressure. That applies to NA engines as well.
If you're interested in more info about backpressure then please read my 2 year old thread: https://www.6speedonline.com/forums/...kpressure.html
Cheers
Old May 15, 2013 | 01:34 PM
  #130
Nice to hear that you enjoy your new EP2.
Old May 15, 2013 | 06:57 PM
  #131
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
Do you guys with 600+ HP kits track the cars? Or are they more the straight line stuff and getting a ridiculous rush driving around and remote runs? I really like tracking my car and wouldn't mind some more power but I want to make sure it's reliable. Are there kits more geared towards a track focus? Or should I just focus on handling upgrades? I have close to 500 hp on a dyno now.
Old May 15, 2013 | 07:01 PM
  #132
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
I haven't tracked mine yet. I plan to. I probably have 100hp more than you at the wheels right now. I can see how it would be a handful on the track.
A good friend of mine has a bunch of exotics and tracks a lot of them. He told me that anything over 500hp (I'm assuming he meant at the crank) and the cars became a lot more difficult to drive. He also preferred N/A powerplants to turbos.
RS GT3 RS
Sep 24, 2015 09:27 PM
Aug 21, 2015 06:34 AM
