TPMS monitor disapeared
Old Apr 27, 2013 | 11:08 PM
montreal911's Avatar
montreal911 is a splendid one to beholdmontreal911 is a splendid one to beholdmontreal911 is a splendid one to beholdmontreal911 is a splendid one to beholdmontreal911 is a splendid one to beholdmontreal911 is a splendid one to beholdmontreal911 is a splendid one to behold
Hi Guys,
I need your help please. Took my car for a drive today and as I'm goin through my dashboard menu to see my tire pressure I notice its gone! Even when I try goin in the settings the TPC option is not there anymore.
Can anyone help me understand what happened and how I can fix this?
Sam
Old Apr 28, 2013 | 11:39 AM
40TO60N1's Avatar
40TO60N1 is infamous around these parts
Are you missing the TPMS menu completely or you have an alarm and the TPMS shows "--" for all the tire pressures?
Just happen to me the other day and currently all the pressures show "--". The driver rear sensor was going... now the whole system went south. Going to have the dealer check it out and hope the extended warranty kicks in for the repair.
Old Apr 28, 2013 | 01:54 PM
TT Surgeon's Avatar
Batteries might be dead.
Old Apr 28, 2013 | 02:09 PM
BaldBag's Avatar
BaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant future
When u figure out how to turn it back on. Please tell me how to turn it off. I have new tpms sensors in the box, forgot to put them in when I mounted the tires on the new wheels.
Old Apr 28, 2013 | 02:16 PM
40TO60N1's Avatar
If one of the sensors goes out, will it affect the complete system?
Not seeing any read outs from the other wheels either.
Chance of all 4 sensors go out at the same time, is slim. (My 2 cents)
Old Apr 28, 2013 | 05:50 PM
TT Surgeon's Avatar
If two are out nothing will read, the battery life is 5 yrs, they tend to go out at about the same time. They can be installed without dismounting the tires.
Old Apr 28, 2013 | 06:06 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
Unless someone disabled it thru Durametric?
Old Apr 28, 2013 | 07:04 PM
bbywu's Avatar
I thought that TPMS can not be disabled without pulling the control unit?
https://www.6speedonline.com/forums/...etric-pro.html
Old Apr 28, 2013 | 08:10 PM
TT Surgeon's Avatar
What shows on the screen, "--", that would imply batteries. A blank screen is another matter.
Old Apr 28, 2013 | 09:00 PM
Berndindallas's Avatar
Berndindallas is infamous around these parts
If one or all of the batteries are dead, wouldn't you get a 'TPMS inactive' alert? I messed up my display setup once and cursed Porsche until I found out that I accidentally changed settings...make sure you read the manual....happens to the best of us
Old Apr 29, 2013 | 12:47 AM
Hi, i'm missing the menu completly... I deflated one of my tires and i got a message on the screen saying i have a flat which means the sensor in the wheel is communicating. But i still dont see the tpms menu or readings at all when i scroll through my options.
Old Apr 29, 2013 | 06:55 AM
bbywu's Avatar
Did you try and "re learn" the sensors?
Even though the TPMS display is missing, is the option to set, change and learn still available in the submenu?
https://www.6speedonline.com/forums/...pressures.html
Old Apr 29, 2013 | 08:34 AM
No its not.
Old Apr 29, 2013 | 08:44 AM
bbywu's Avatar
The only thing I can think of is that the gateway in the instrument cluster got reprogrammed somehow. Do you have Durametric or access to PIWIS?
Old Apr 29, 2013 | 11:37 AM
I was thinking the same or i should say hoping for this so it will be an easy fix. I dont have durametric but will take it to the garage tmr to see if that's what happened. Will let you know, thanks for the help.
