Intermittent Beeping - Mainly on track days
Old Jun 1, 2013 | 11:36 AM
palisades's Avatar
palisades is infamous around these parts
Hi guys,
My car has been making an intermittent beeping noise lately during track days. It is the same beep as when it warns you of low fuel or low tire pressure. There are no dash indicators or warning lights. What could this be? I have a softtronic tune and euro pipe exhaust. Very confused. Did an extensive search online and can't find anything on the subject.
Have any of you run into this?
-mike
Old Jun 1, 2013 | 04:32 PM
AZTurbo's Avatar
AZTurbo is infamous around these parts
This sounds like a ridiculous answer but could it be your speed warning? Maybe you only hit that preset speed on the track? Probably a shot in the dark.
Old Jun 1, 2013 | 05:24 PM
Macster's Avatar
Dig out the owners manual and look up the meanings of the warning indicators/lights.
The problem could be low coolant or low washer fluid.
Or something else.
Old Jun 2, 2013 | 10:26 PM
palisades's Avatar
There aren't any warning indicators lights. It happens at low speeds under heavy deceleration, so I don't think it is the MPH limit. It happened a bunch of times through the s turn at the top of the hill at the big track at Willow Springs yesterday for those of you in California.
Old Jun 3, 2013 | 01:22 PM
bbywu's Avatar
OEM seats?
Old Jun 3, 2013 | 02:25 PM
palisades's Avatar
Yep. The air conditioned sport seats.
Old Jun 3, 2013 | 04:13 PM
TT Surgeon's Avatar
Brake pads got enough meat?
My old c4s used to do that when the brake sensors were close, or when the brake fluid overheated.
I assume you flushed the brake fluid with hi temp fluid?
Old Jun 3, 2013 | 04:33 PM
palisades's Avatar
I'm running the hi-temp fluid. Good question on the brake pads, I just assumed it would give me a brake warning light. I'll have that checked.
Thanks.
Old Jun 3, 2013 | 05:23 PM
TT Surgeon's Avatar
Is the fluid fresh?
Or is your psm/abs kicking in?
Old Jun 3, 2013 | 05:44 PM
palisades's Avatar
The fluid has only seen 2 track days.
Old Jun 3, 2013 | 06:30 PM
TT Surgeon's Avatar
If its only on hard braking, it's gotta be related to brakes, suspension or sensor systems.
Interesting problem, def try and get it sorted b4 your next track day, GL.
Jul 29, 2019 11:13 AM
jyupitt1
Sep 23, 2015 06:26 AM
mikespeed95
Sep 14, 2015 09:48 AM
mjacobellis
Aug 20, 2015 09:13 AM
pwdrhound
Aug 20, 2015 05:54 AM
