997.2 tts oem air filter restrictive?
Old Jun 17, 2013 | 07:21 AM
0-60freak's Avatar
0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light
I have been reading that you should replace the factory air filter element because oem is restrictive . With all of the hundreds of millions in r&d why does Porsche not get it right?? Is this true.....and does anyone have any recommendations ?? 2012 997.2 tts
Old Jun 17, 2013 | 08:02 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Unfortunately it's true. The original filters are designed to be disposable. If they put in a cleanable filter, then they'd have to worry about making sure people actually clean them. They'd also lose a ton on service income...lol.
Go with a BMC drop-in filter. Inexpensive, re-usable, and much less restrictive then the factory paper filter. We use these in all our power kits, included our 9 second TTS.
http://www.championmotorsport.com/product-p/593-04.htm
Old Jun 17, 2013 | 08:23 AM
0-60freak's Avatar
thanks for the info and the link....I'm installing a Europipe with 100cell cats this weekend so I guess I need to be able to suck more air!
Old Jun 17, 2013 | 10:05 AM
kw911TT's Avatar
kw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud of
Interesting read from a few weeks back.
https://www.6speedonline.com/forums/...x-we-test.html
Old Jun 17, 2013 | 11:20 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
This is a bit of a misnomer. If proper service intervals are followed, there is nothing wrong with the oem filters. The aftermarket freeflow filters don't filter as well and if you over oil them, which most people do, you run the risk of fouling up your MAF sensor.
Stick with Oem and change out every 15-20k. It's cheap and easy to do yourself anyway
Old Jun 17, 2013 | 11:40 PM
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Don't worry about the air filter!
Wake up the beast! Get a good flash!
Old Jun 18, 2013 | 07:06 AM
0-60freak's Avatar
Thanks for the link kw911tt and the advise Jako.....I believe I will just skip the element swap....Leo997tt I am worried about the warranty repercussions of messing with the computer....I'm going to tackle the europipe swap this week and go from there.
Old Jun 18, 2013 | 07:53 AM
Jako's Avatar
No worries and good luck with the mods. I also forgot to say that unless you are going to increase the amount of intake you need to ensure you match the output. I've seen people loose power by loosing the proper back pressure as well as increasing intake and loosing power due to too much back pressure.
I would go to a tune shop to get them to match the tune with your exhaust mods to get the best ratios.
Old Jun 18, 2013 | 04:25 PM
0-60freak's Avatar
I think I will just install the europipe and leave it at that ...Europipe states 25-30hp gain and that would put me at 560hp and 0-60 around 2.9sec....
Old Jun 18, 2013 | 04:35 PM
jhbrennan's Avatar
Where did you read that - remember if it's on the internet, it has to be true.
Old Jun 18, 2013 | 04:45 PM
0-60freak's Avatar
probably read from a article written by a air filter manufacturer :-)
Old Jun 18, 2013 | 04:51 PM
LeoLambo's Avatar
Lamborghini Fanatic
I read the engine, turbos & transmission have to be replace it too because it doesn't make enough power.... Those guys in Germany are very dumb... Why they will be making such a bad cars....
Old Jun 19, 2013 | 11:22 AM
Frizz's Avatar
Frizz is infamous around these parts
For sure oem paper filters are restrictive. And maybe these dumb Germans just want to make sure, if you wish a less restrictive filter you run it at your own risk. E.g. all the MAF trouble is now your problem.
Weebs
Nov 29, 2018 08:20 AM
tropicatango
Dec 4, 2015 02:45 PM
The Oss
Aug 24, 2015 08:19 PM
