Sway bar vs springs
Old Jun 28, 2013 | 03:25 PM
stltri's Avatar
stltri has a spectacular aura aboutstltri has a spectacular aura aboutstltri has a spectacular aura about
Sway bar vs springs
Has anyone upgraded the stock sway bars (adjustable rear only or both) without upgrading the stock springs? I'm fairly content with the ride in either normal or sport mode. But I figured, the upgraded sways will give some performance benefits (decrease the understeer for example) on the track and will not affect the street ride.
Why not lowering springs also? The scraping bother me and I would hate to limit where my car can go. I'm already scraping in a few areas as it is.
Then there's also LFCA options..
Old Jun 28, 2013 | 06:43 PM
DNugget991GT3's Avatar
sways affect the handling of the car more than springs. In other words, a stock height car with sways would out handle a lowered car with stock sways on lowered springs or coilovers.
Old Jun 28, 2013 | 06:59 PM
bbywu's Avatar
They address different aspects of handling. If you are looking to dial out understeer, improve turn in, etc, you could consider proper alignment + stiffer/adjustable rear sways.
Old Jun 28, 2013 | 08:18 PM
TT Surgeon's Avatar
Just like mine, stock springs, gt2 rear sway.
Old Jun 29, 2013 | 08:10 AM
stltri's Avatar
Appreciate everybody's input.
But no comment on the LFCA? No advantage other than adding more camber? I guess this falls under Bob's comment about proper alignment.
Old Jun 29, 2013 | 08:11 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
A stiffer rear sway will help to eliminate understeer...its a 5 minute job to install while on the other hand a front is not needed and it needs around 2 hours for installation...Personally i love lowering my cars so hr springs were installed when the car was bought...However after driving many sway/spring combos my opinion is that best handling with STOCK shocks is with just a stiffer rear sway bar...
Old Jun 30, 2013 | 01:39 AM
kpt6's Avatar
kpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond reputekpt6 has a reputation beyond repute
Old Jun 30, 2013 | 01:04 PM
TT Surgeon's Avatar
I also run the gt3 front control arms, I easily run -1.3-1.5 up front no issue at all. I would also suggest gt3 toe links rear, "while your there".
This is what ya need:
Old Jun 30, 2013 | 08:25 PM
stltri's Avatar
How much are these parts and how much labor involved? Or should I start with the GT2 sways first and then decide?
Old Jun 30, 2013 | 08:30 PM
TT Surgeon's Avatar
Def gt2 sway first, takes ten minutes to install. That may be all you need, the other items are getting track oriented, kinda.
The parts run around 1300 from tarrret labor700-1000.
Rguy
Apr 12, 2020 11:11 PM
Texas1
Sep 20, 2015 09:12 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
AdamNoone
Sep 3, 2015 04:15 PM
