New data log
Old Jul 4, 2013 | 09:37 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
New data log
I managed to sort a few issues I had with my car and it seems to be running better so I quickly popped out for a drive and it was quite busy but I managed to have a little blast and took this log.
I will do some more later but wondered if you could take a look please
File Type: xml
Old Jul 4, 2013 | 01:26 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Not bad Nick! Who's your tuner, what mods do you have, fuel?
Old Jul 4, 2013 | 01:34 PM
GTRNICK's Avatar
I'm out data logging right now will post more soon.
Old Jul 4, 2013 | 02:46 PM
GTRNICK's Avatar
Fuel type; 99 ron
Mods;
FVD Software,
FVD cat less exhaust,
FVD LWFW and clutch,
Aerospace Intercoolers,
IPD Plenum,
IPD Y-pipe,
GT3 TB,
Stock turbos and headers.
Old Jul 4, 2013 | 03:00 PM
GTRNICK's Avatar
Here is a new log.
I also have a few more.
File Type: xml
Old Jul 4, 2013 | 04:01 PM
TTdude's Avatar
Looking good Nick!
Old Jul 4, 2013 | 04:10 PM
GTRNICK's Avatar
Thank you.
What do you think of the coolers?
Old Jul 4, 2013 | 05:16 PM
GTRNICK's Avatar
Another one.
File Type: xml
Old Jul 4, 2013 | 09:18 PM
bbywu's Avatar
Nick, for your second pull, your IATs reach about 46C, which is reasonable. However, without doing a sustained load with several VMax pulls, it is hard to say how easily it gets soaked. For the purposes of that specific run, your ICs seem to be doing their job well. However, it's hard to say what the thermal efficiency is without measuring the temperature before and after the IC...Durametric won't log that info, you'd have to put a probe into the pipes before and after the IC to get that data.
Old Jul 4, 2013 | 09:20 PM
TTdude's Avatar
Originally Posted by GTRNICK
Thank you.
Imho, 20 deg differential is too much, similar to stock.
Old Jul 4, 2013 | 09:31 PM
bbywu's Avatar
In log 2, initially, it looks like the ECU is pulling a timing at peak torque around 5K RPM. It maintains reasonable Lambdas and a boost of about 1.2 at this point. As you reach 230 km/h, at peak torque, you start to run rich.
I'm not sure why, as your IATs seem okay, unless you are just letting off the gas at that point.
Old Jul 4, 2013 | 10:05 PM
TTdude's Avatar
Definitely running rich-- losing power in that region, you can see it in the curve.
Old Jul 4, 2013 | 10:26 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Disregard. Looks like those are in km/hr.
Yeah seems to go pretty rich up top. IATs are "ok" for 1.2-1.3 bar up to those speeds -seems like they were a touch better on some of your older logs though. Have you run a leak check lately?
Old Jul 5, 2013 | 11:53 AM
cannga's Avatar
Looking good Nick!
Dave, is the blue curve a graph of engine load from the Nick's data above? Don't know if I am missing something (new to this of course) but it seems Nick's data shows max engine load is at around 4400 rpm , here it is at 3000, making the torque plateau a lot wider than it should be?
Old Jul 5, 2013 | 12:08 PM
GTRNICK's Avatar
I hit end of 4th and released.
