Extended warranty
Old Aug 11, 2013 | 09:42 AM
Trauma's Avatar
Trauma is infamous around these parts
Extended warranty
I own a 2008 turbo cab with 40k miles. My CPO expires in 2 months. I am looking at a third party extended warranty from Auto Advantage that will cost $5800 and provide me coverage for another 5 years and up to 100,000 miles. I do not plan to sell the car anytime soon, but if I do, the warranty is fully transferable.
Everything is covered with the exception of following exclusions (taken directly from the brochure):
Policy Exclusions:
(The parts listed below are not covered. Therefore any part not listed is covered under this coverage per the terms of this agreement):
Any servicing, maintenance, tune-ups, oil changes, fluid replacements, etc. as recommended and required by the manufacturer including adjustments and alignments (except when required in conjunction with a covered repair). Any part to normally designed to be serviced or replaced within usage during the life of the vehicle, such as, but not limited to: filters, lubricants, coolants, fluids (except when required in conjunction with a covered repair), spark plugs, spark plug wires, glow plugs, light bulbs, fuses, brake rotors, brake drums, brake pads, brake linings, manual/hydraulic/electronic clutch assemblies, shock absorbers, battery, battery cables, throttle body assembly (except injectors), exhaust system (except manifold), belts and hoses (except A/C high-pressure hoses).
Is this a good purchase, or is it more cost effective to "take my chances." In don't track the car, and I rarely break 100mph. Ok, 120mph.
Old Aug 11, 2013 | 11:48 AM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
Auto Advantage? However, the coverage looks good though
Have you cross shopped with Fidelity/Costco/Easy Care?
Make sure you get the quotes while the car is still under warranty?
Old Aug 11, 2013 | 12:28 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Sounds like a great policy with minimal exclusions. I haven't heard of the company though to know if they will actually pay.
If I could get that same warranty from Fidelity I would in a second.
Old Aug 13, 2013 | 10:34 AM
glassyp's Avatar
glassyp has a spectacular aura aboutglassyp has a spectacular aura about
I bought an extended warrenty directly from Porsche when i purchased my 09 997tt, and have absolutly no problems with them servicing my car.. Call your local dealer and see what company they recommend...
Old Aug 13, 2013 | 01:15 PM
jhbrennan's Avatar
Better yet, ask your service advisor which of the aftermarket warranty guys are the easiest to work with. My dealer sells one brand but SA recommends another.
Old Aug 13, 2013 | 01:28 PM
dweintra's Avatar
dweintra is infamous around these parts
I say save the $5,800 and gamble with it if the car is solid. $5,800 can fix a lot of items.
Old Aug 13, 2013 | 01:35 PM
glassyp's Avatar
JHBenner even a better idea,
Old Aug 13, 2013 | 04:48 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
Bad idea. I had my tip transmission replaced at 30k miles for a leak. Covered under warranty. Cost? $15k. These cars are way too expensive and costly to repair outside of warranty. Plus it just gives you added piece of mind. I got mine thru fidelity right before it hit 35k miles (you get price jumps at different mileage points) for 5 yrs 60k miles, $250 deductible for $3600. One major issue in 5 yrs is likely to happen and it'll more than pay for itself. My 2 cents
Rguy
Apr 12, 2020 11:11 PM
jaehoppa
Oct 22, 2015 09:17 PM
bzimpfer
Sep 26, 2015 10:55 PM
yumaverick
Sep 2, 2015 03:48 PM
