850 rwhp gt2 tires
Old Sep 22, 2013 | 06:30 PM
mike_tt's Avatar
mike_tt is infamous around these parts
850 rwhp gt2 tires
My friend have a 2009 gt2 with 850 rwhp with stock wheels . Now he is using michelin cup tires and car is spinning to much with these tires at 60 mph rolling . What tires do you suggest to use on stock fitmment ??
Can we use nitto nt05r 345/30/19 or its too big ?? Or hankook rs3 , toyo r888 ??
Old Sep 23, 2013 | 07:48 AM
orbelo's Avatar
orbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud of
I use hoosier R6, with 850whp and 860lb torque. 345x30x19. You will need to warm them up. If your power comes in early. I have used R888, Perilli Corsa. The R6 hold the best. Just be careful during cold weather. You'll have issues regardless of tires.
Old Sep 23, 2013 | 12:45 PM
MegioN's Avatar
MegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to allMegioN is a name known to all
I am also using R6 tires, best of all for high powered cars. My size 315/30/19
Old Sep 23, 2013 | 01:47 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
How big can you fit without rubbing or sticking out well beyond the lip?
Old Sep 23, 2013 | 05:06 PM
Nasser's Avatar
Nasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant future
The best way to go is 18'' wheels and mickey Thompson's
Old Sep 23, 2013 | 05:12 PM
TrackAddict997's Avatar
TrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the rough
Yeah id like to know the same?
Old Sep 24, 2013 | 06:26 AM
TwinTurboM3's Avatar
TwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud of
Megion, do you have hoosier on front axle as well?
Old Sep 24, 2013 | 09:07 AM
MegioN's Avatar
Yes, on front i got Hoosier a6. Same was at rear but they died very fast
Also I have Hoosier drag radials 335/30/18 for drag passes only. This tires very unstable at high speed, after 250 kmh but have phenomenal grip in compare with r6
Old Sep 24, 2013 | 11:07 AM
Do the Hoosier Drag Radials have White colored letters on the sides?
I felt scary on Hoosier DR. Switched back to MT ET Streets.
You are correct A6 die faster than R6.
In your case I would not use non-treaded on front axle. I would put a set of Pirelli Tropheo with some treads on it.
Old Sep 28, 2013 | 07:51 AM
mike_tt's Avatar
Guys .. the car is a dd so we can't put hossier it is so dangerous for street use right ??
How about nt05 335/30/19 or smaller size like 305/30/19 or pss stock size 325/30/19 give me some good ideas because I want to put 345 but im affraid of the side walls .. can u help me guys ?
Old Sep 29, 2013 | 10:56 AM
orbelo's Avatar
Hoosier R6 will be just fine on the street. I DD my car with no issues. Only during rain and snow it will be dangerous can't see why you would be driving that car in those conditions anways. I went through a brand new set of pirelli Corza's in three months with this power level, and got good traction for the first month only.
Old Sep 29, 2013 | 12:45 PM
mike_tt's Avatar
i think i will choose the hoosier r6 .. but is it good for high speed because every weekend we use the 5th and 6th gear a lot ..i mean is it safe above 340km+ ?
Old Sep 29, 2013 | 12:49 PM
orbelo's Avatar
No problem, we average 170mph+ in Mexico Ofcourse.
Old Sep 30, 2013 | 02:01 AM
when you go on hoosier's webpage a pop screen comes on saying "not DOT" legal etc...
If you are seeking advice to go 340 + km/h on the Street you have a mental problem, just buy the cheapest tires as you will sooner or later pass away. No matter which tires you have...
Old Sep 30, 2013 | 05:12 AM
MegioN's Avatar
Hoosier R6 are DOT tires, they are street legal, aslo they marked to 300+ speed.
+1 about racing 340+ at street, its way to much. Even 300 is fast enough and very dangerous.
