The journey continues!!!
SubscribeQuote:
Mahle 3.8ltr slip fit pistons and liners,Originally Posted by 93ls1rx7
Let us know what you decide!
Carrillo rods,
Shrick cams,
Gt3 RsR motorsport oil pump,
The rest is all new OEM parts.
By end of tomorrow they reckon the engine will be fully stripped and cleaned.
I must say the guys at FVD did a great job with the build and worked on the engine solid for me to get it finished in a short space of time.
I had a great time watching them do the build and being able to take pics of the masters at work which I feel very fortunate for.
I just cannot wait to get the car run in and the ECU remapped for full power as it's on a safety map for now.
What I do know is it feels like a different breed now it is so torquey its unreal and it only hits a bar max under load so I can only imagine what it will be like when it is finished off.
Quote:
Cheers for the kind words sir. Originally Posted by 93ls1rx7
Congrats Nick. Sounds great and I am sure it is a different animal. Looking forward to seeing the dyno results as I am considering a similar build.
I look forward to the results too!
What is your name by the way?
Great job!! And thanks for all the pictures. What kind of a break-in process are you going to follow and what oil are you running. It's really amazing watching this all come together. Will wait for your performance report.
Quote:
I'm doing up to a 1000miles on a 10w 40 mineral oil.
I did the first change including oil filter between 30-40 miles just to makes sure everything was okay then reset the counter.
Then today I did one at 250miles including filter and still everything is fine no lumps of metal
So now I will do 400miles till next change including filter and then the same again so that will take me up to the 1000miles mark or just over.
Then I will switch the oil to 0w 40 fully synthetic and drive to Germany for the software upgrade.
This is the longest 1000miles of my life
Quote:
I need to do the same.
What head studs and gasket did you use?
How many days did FVD needed to rebuild the engine?
Originally Posted by w00zy
Very nice!I need to do the same.
FVD recommended I use the stock Gaskets and studs as ***** said "Porsche know what they are doing".
They did look after me as they did something they don't usually which was build it in 5 days but ***** told me it's usually minimum 2 weeks turnaround.
Another thing you have to remember they give you a 2 year guarantee on the build as long as you are using their turbos etc...etc...
