IPD plenum installed today
Old Nov 12, 2013 | 10:37 PM
  #91
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
Originally Posted by Thomas@GIAC
Your tune should be for 100 octane, as we have never explicitly sold a leaded 110 file.
Thanks for the info. The guys at WMS said it was a 110 UNLEADED tune so I ended up buying 110 unleaded in 5 gallon pails which ended up being really expensive. There's a place 2 miles from my house that sells 100 and 104 unleaded at 1/4th the price. Your post is great news for my wallet. Just to verify, you've never done a 110 unleaded file either?
THanks!
Old Nov 12, 2013 | 10:55 PM
  #92
faiz's Avatar
faiz is just really nicefaiz is just really nicefaiz is just really nicefaiz is just really nice
Someone needs to do a black friday special on these
Originally Posted by PelicanParts.com
And don't forget Pelican Parts - we're proud to now offer IPD Plenums! Read further product information here.
Mark/Pelican Parts
Old Nov 13, 2013 | 10:51 AM
  #93
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
THanks!
We have done a 110 leaded file for a competition, but I don't believe it has ever been offered publicly. We see great results with unleaded 104, and this is typically what I recommend for those utilizing the race file.
Old Nov 13, 2013 | 11:21 AM
  #94
swc's Avatar
swc
swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !swc Is a GOD !
The check valve came yesterday from IPD and I installed it. Thanks Greg for 2nd day air shipping for free! I will run again with my friend this weekend and see if this mod can catch 2 car length.
Old Nov 14, 2013 | 07:50 PM
  #95
swc's Avatar
swc
OK question for you guys. I installed the check valve yesterday and dove about 20 miles so far and I just got error code B1902 "Turbocharger Underboost". My Durametric says boost below lower limit value. Does it mean boost leak somewhere? On the stock gauge, boost seems to be fine and the car pulls strong. Why did I get this code? Please help!
Old Nov 14, 2013 | 09:09 PM
  #96
CBADtt's Avatar
CBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant futureCBADtt has a brilliant future
No idea, but on the bright side, if there is a problem, maybe the car will pull even harder once fixed.
Old Nov 15, 2013 | 05:47 PM
  #97
locus's Avatar
locus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond repute
Originally Posted by longboarder
Thomas this thing just keeps getting faster and faster as it adapts. I put 10 gals of 100 octane on the 91 file and holy crap...I can't wait to fill it up with 100 and try the 100 octane file!
Is it even possible to put 100 octane with 91 pump map?
Any gain with pump map?
One question for Thomas, Is pump map consider as 91 map?
I have pump map but I only put 93. Is there any difference between 91 and 93 octane?
When running with either 91 or 93, is there any difference in terms of power gain?
Old Nov 16, 2013 | 09:24 AM
  #98
longboarder's Avatar
Yes I ran the 91 tune with a blend of 5 gallons 91 oct and 10 gallons of 100 oct and there was a noticeable power difference as the dynamic nature of the ECU allows for higher boost/timing targets even when tuned when higher octane levels are introduced. GIAC can provide more details on this as my understanding is very basic.
Old Nov 18, 2013 | 10:01 AM
  #99
swc's Avatar
swc
Finally ran with my friend's 997TT. Yes, IPD plenum works!
These two short videos tells everything. First video, I was in the camera car with passenger(please ignore her laughing). My friend also had a passenger too on that run. I had Softronic tune with Fabspeed exhaust and he had GIAC tune with AWE Tuning exhaust. So basically we had a same mods except different tuners and brand. As you can see, I lost about 2 cars at the end of run(~130mph). I was embarrassed about the difference!
After I installed IPD plenum last week and we ran again. This time we didn't have passengers and took the video from another car(other friend's GTR). My car was on left and his was on right. We were almost dead even. Tried few runs with the same result. So the plenum should have made 25~35whp as IPD advertised. What a small big improvement for such a small change! IPD rocks!
http://instagram.com/p/g1Z7byKRGs/
Old Nov 19, 2013 | 12:52 PM
  #100
Tarasser's Avatar
Tarasser is infamous around these parts
Now you need a giac to win
Old Nov 19, 2013 | 04:28 PM
  #101
It is certainly possible, and as Longboarder said you will see a slight performance gain (albeit a smaller one than running the dedicated 100 octane race file). For the 997.1, the pump files are specific to octane availability. This means that your installer will give you the correct file that matches your region's premium fuel. So in your case, you will have a 93 octane pump file.
The 93 octane file does make more power than the 91 octane file. Typically, we see another 15-20 wheel horsepower with 93 octane.
Old Feb 7, 2014 | 07:38 PM
  #102
fireballr32's Avatar
fireballr32 is a jewel in the roughfireballr32 is a jewel in the roughfireballr32 is a jewel in the roughfireballr32 is a jewel in the rough
sorry to bring up this old thread but i cant write pm's yet and would really like to know the reason for this error code and how the problem has been solved. swc?
cheers,
Luke
Old Feb 7, 2014 | 10:35 PM
  #103
997ttR's Avatar
997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light
Originally Posted by fireballr32
sorry to bring up this old thread but i cant write pm's yet and would really like to know the reason for this error code and how the problem has been solved. swc? cheers, Luke
Log out and then log in again
Old Feb 8, 2014 | 04:54 AM
  #104
swc's Avatar
swc
cheers,
Luke
Hey Luke, since I cleared the code it hasn't come back yet. I still don't know why I had this code. Maybe false alarm?
Old Mar 12, 2014 | 02:20 PM
  #105
michaeldantep's Avatar
michaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud ofmichaeldantep has much to be proud of
Originally Posted by IPD Greg
Greetings again 6 Speeders,
The 997.1 Turbo IPD Plenum delivers horsepower gains of 30 to 35 and Torque gains of 35 to 40 at the wheels. The 997 Turbo plenums deliver smooth and linear power with considerably quicker boost response creating a longer, stronger and more desirable power and torque curves. The IPD Turbo plenums deliver reliable performance for both stock and heavily modded Turbos and no additional mods are required, including any ECU tuning. All of our HP claims are from bone stock test cars but they are an absolute must for any performance tuned Turbo. We offer 74mm Plenums that utilize the factory OE 74mm throttle body (TB) as well as an 82mm “Competition” version that requires upgrading to the larger 82mm TB. Click on the link below for details or feel free to drop us an e-mail or give a call anytime.
http://ipdplenums.com/products/plenums/9971-turbo
Cheers,
Greg
Are the gains in HP and torque similar for the 997.2 Turbo?
