How does the AWD & center diff handle power slides on a 911?
Old Nov 25, 2013 | 08:45 PM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
Can I push the 997 911TT into a corner and make its tail come out easily and nicely? (All T/C off)
I am debating a modified '07 because its cheap and its a manual, but I wonder if I will have fun with it and it's AWD... ?
Old Nov 26, 2013 | 08:09 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Yes with traction off and sport mode on (gives more power to the rear) you can easily slide the rear end out. However the awd system is always working with you to ensure you get through the corner as as fast as possible. This makes it not as fun and partially unpredictable as you never know where exactly the power is to go but it always works out in your favor. It is pretty neat experiencing the awd do its work.
Thus; you can easily slide the car however it will never be as fun or predictable as a rwd.
Old Nov 26, 2013 | 05:01 PM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
The AWD system is weird.
Car feels like a RWD till the middle of a drift, then the AWD system starts to do its job and the car feels weird.
An LSD would help but there isn't one for the Tiptronic
Old Nov 26, 2013 | 06:06 PM
Fantasma's Avatar
It looks annoying!!!!!!! Forget it then
Old Nov 26, 2013 | 06:27 PM
mattgarrett's Avatar
mattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the roughmattgarrett is a jewel in the rough
I have never had a problem drifting mine, very predictable and fun!
Old Nov 26, 2013 | 06:43 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
You need to be patient learning the limits of the car. When I. Was young in my M3 and Z cars it was easy to slide and I learned the hard way many time how good I. Was NOT.
The 911tts is just a fun once you learn it and faster through the turns will less drama. I like it at 47 with such an expensive car
Old Nov 26, 2013 | 07:23 PM
E90076's Avatar
E90076 is a name known to allE90076 is a name known to allE90076 is a name known to allE90076 is a name known to allE90076 is a name known to allE90076 is a name known to all
Agreed. I'm also coming from a Z and M3 (350 and e90 respectively). Both were very predictable and easy to drift for an amateur like me.
It can be done in the 911TT but you have to push the car harder to provoke the drift...which results in a less predictable drift. It's a little scary to be honest - hard to tell when and how hard the tail is going to kick out. Also, the traction control kills any slip angle unlike the MDM in the BMWs that allow some drifting but will save you if you push it too hard.
All that being said the 911TT is still a fun car to drive.
Old Nov 26, 2013 | 08:17 PM
spf4000's Avatar
spf4000 is a jewel in the roughspf4000 is a jewel in the roughspf4000 is a jewel in the roughspf4000 is a jewel in the rough
AWD cars are not exactly meant to be drift machines, so if that's what you're looking for, get an FR, or if you want to go with a 911, stick to the RWD variants. It's very easy to get the tail to step out on the TT but the front wheels reign that in rather quickly in dry conditions. Wet surfaces tend to make it slightly easier to do flashier drifts in the TT, and the transitions feel smoother as the front grip takes a bit more time to bite and bring the drift under control. I say slightly as the rear weight bias still makes it pretty hard to control the drift consistently, at least for me.
Old Nov 26, 2013 | 08:48 PM
Fantasma's Avatar
From the video it is worse than my old GTR which I was able to powerslide even though it was AWD, I could keep the tail stepped out as the torque overrode T/C when in triple-R mode and the LSD helped it out as well.
So far my 2 best cars to power slide in are my old F10 M5 and my 458.
My F10 M5 I could hang the rear out, then pop out even MORE and bring it back in... like a dual stage power slide, hehe, perfect for thrilling passengers who thought the first bump out was as far sideways as I would go.
I hate my ML63's transmission and traction control though, can't really do crap with that transmission and the fact that I can't even disable T/C fully. Swapping it for another M5/M6 in a few months.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
PelicanParts.com
991 Vendor Classifieds
Aug 20, 2015 04:53 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
991 Turbo Vendor Classifieds
Aug 20, 2015 02:27 PM
PelicanParts.com
Aug 18, 2015 03:47 PM
