08 Turbo won't start. Lots of fail msgs
Old Dec 1, 2013 | 09:27 AM
rdf16's Avatar
rdf16 is infamous around these partsrdf16 is infamous around these parts
Started happening this week. Just got the car about 3 weeks ago, 08 Werks 1
Turbo with 5800 miles.
Drive the car from cold then it sits for 3 to 4 hours. Go to start and get;
PSM fail, ABS fail and depress clutch, sometimes also indicator fail, oil gage
fail and system fail visit workshop. I changed the clutch switch and added a
new battery, thought everything was fine then same thing last night. After
messing with it for 45 min finally got it to start with just PSM fail, depressed
the brake a bunch and the abs fail went away, just luck I think.
Read a 4 year old post from a guy here that had the same sounding problem
but he never reported back, pm'ed him.
No leaks that I can see and I wen through all the fuses.
Old Dec 1, 2013 | 09:47 AM
19000rpm's Avatar
19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute19000rpm has a reputation beyond repute
If you have a Durametric or other scan tool, scan the car for codes. I bet there is something stored in the memory. Otherwise you're just throwing parts at it. If you don't have a scan tool of some sort, it may just be easier to get it towed to the dealer.
Old Dec 1, 2013 | 09:51 AM
rdf16's Avatar
Yea, about to go down and try my scan tool. Tried the same tool at my buds
house Thur and it wouldn't register, same tool I used on my previous 07 GT3
and it worked fine. Going to the dealer Tue.
Old Dec 1, 2013 | 11:25 AM
rdf16's Avatar
Started fine, no codes on the reader.
Old Dec 1, 2013 | 12:03 PM
Zero911's Avatar
Zero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to all
I would have expected that to be a battery issue. When it fails to start, do you hear clicking noises? All those errors and your symptoms seem to match a bad battery, but you said you replaced it. What type of battery did you get?
Old Dec 1, 2013 | 01:49 PM
rdf16's Avatar
Ran the car for a while, checked the battery and looks like the alternator is charging. One
strange thing, the brake lights do not work and a light on the right rear, inner red light, is
not working. Fuse is good. The car was CPOed before it was sent out. I thought I saw
something about rear lights not working. Could a brake pedal switch cause all of the
above?
Old Dec 1, 2013 | 03:12 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
If it is CPO'd I wouldn't spend another second trouble shooting it. Let Porsche fix it!
Old Dec 1, 2013 | 05:59 PM
rdf16's Avatar
It's going in on Tue. Can't help trying to trouble shoot though.
Old Dec 2, 2013 | 07:59 AM
Duff0000's Avatar
Duff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond repute
Keep us updated on what the problem was!
Old Dec 2, 2013 | 07:51 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
We're guys. That's what we do! But seriously, keep us posted.
Old Dec 3, 2013 | 09:16 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I know on the 996's a bad ignition switch can cause issues too.
Old Dec 3, 2013 | 09:48 AM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
above?
not trying to be a d*ck but shouldnt you have got that fixed before driving it and risking causing an accident
good luck with the issue though, good thing its cpo, sounds like it could be a real pita
Old Dec 3, 2013 | 03:45 PM
rdf16's Avatar
Had no idea the rear lights were acting up, it came right to me certified pre
inspected by the dealership. First time I noticed was the morning after I
got it home Sat night, haven't driven it since but will have to get it to the
shop. No messages on the lights and all fuses are good, I think I might also
have a bad brake switch, will find out when I get it to the shop, too much
snow today.
Do you check your brake lights every time you get in the car? Maybe i
should add that to my pre-filght.
Old Dec 3, 2013 | 08:23 PM
Jako's Avatar
Wouldn't there be some sort of brake light out indicator on the dash? Or is the complete dash lighting up with failures?
Old Dec 3, 2013 | 08:35 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by jako
wouldn't there be some sort of brake light out indicator on the dash? Or is the complete dash lighting up with failures?
no!!!!!
