do your pccbs act like this ?
Old Feb 28, 2014 | 12:42 AM
DNugget991GT3's Avatar
Guys,
im trying to figure out if i have air in my brake lines or if this is normal..
so i was driving home from philly tonight and played with a camaro. (pretty fast car)
we had a few bursts and on the final one i got to 130ish and was hard on the brakes. they didnt bite hard..i had to push the pedal down hard to slow down. it felt like fade but ccb's arent supposed to fade.
im being told that ccb's bite hard initially then go soft and then go hard once theres heat in them. is that true ?
the explanation was that the initial bite we feel is from the carbon deposit on the pads themselves, and then they go soft because the rotors need to get some heat in them to be grabby.
or do i just have air in my system ?
it was 9 degrees btw.
Old Feb 28, 2014 | 01:50 AM
fireballr32's Avatar
fireballr32 is a jewel in the roughfireballr32 is a jewel in the roughfireballr32 is a jewel in the roughfireballr32 is a jewel in the rough
i can confirm that.
not yet experienced some sort of fade.
they should bite instantly imo.
cheers,
Luke
Old Feb 28, 2014 | 04:34 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
I agree. Many runs on the autobahn getting hard on the brakes when someone comes into my lane and each time the car bites HARD
Old Feb 28, 2014 | 05:39 AM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
when was the last time you've changed break fluid ?
also check for any leaks by cap on the break fluid container.
Old Feb 28, 2014 | 09:21 AM
i changed the fluid and the pads in june 2013. i bled the brakes manually as i couldnt get the durametric to do it.
super blue ate brake fluid.
Old Feb 28, 2014 | 04:06 PM
slawek's Avatar
Steve I use Motive -power bleeder- when changing the fluid
http://www.motiveproducts.com/
Old Feb 28, 2014 | 08:55 PM
flyjets's Avatar
flyjets is infamous around these parts
Master cylinder or moisture in your system.
Classic moisture case is my guess.
Ian
Old Mar 1, 2014 | 10:51 AM
so, i just need to completely bleed the system right ?
Old Mar 1, 2014 | 11:51 AM
flyjets's Avatar
Yes that should fix it everytime I have had what your describing I flushed it and was fine.
Do you use a power flush?
I used a MightyVac and didn't work as well.
Ian
Old Mar 1, 2014 | 12:00 PM
the last time we flushed it, i sat in the car, pumped the brakes... we started from one side of the rear and worked our way according to how prosche does it.. there were no air bubbles coming out of the lines once we were done... but i think it might be in the secondary reservior
i dont know what a power flush is, but im assuming we didnt use it... just pumped it out manually.
Old Mar 1, 2014 | 02:26 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Once they are up to temperature they grab instantly and I have not experienced any fade issues.
Old Mar 1, 2014 | 04:18 PM
32krazy!'s Avatar
motive power bleeder . start at the pass rear then driver rear then pass front then driver front.
Old Mar 7, 2014 | 11:18 AM
Machinehead's Avatar
Machinehead is infamous around these parts
How were the road conditions, was it wet outside? I've noticed a substantial decrease in effectiveness if the braking system is wet. ie.. relatively heavy rain, after a car wash..
Old Mar 7, 2014 | 11:49 AM
dry roads. ice cold.
in the rain i have no brakes.
longboarder
Oct 28, 2015 12:10 PM
Michael_s
Oct 7, 2015 11:34 PM
spooltime
Cayenne Turbo
Sep 12, 2015 12:05 PM
Nuke
Sep 8, 2015 09:09 AM
