Porsche Aeroforce OBD2 A/F, Boost Gauge. AWESOME!!!
Old Mar 16, 2014 | 03:55 PM
kinkkink's Avatar
kinkkink is just really nicekinkkink is just really nicekinkkink is just really nicekinkkink is just really nice
Hey all,
When I had my Built SRT8 Jeep I had awesome Aeroforce gauges. They plug directly into the OBD2 port. You can select any PID that the car supports to display on the gauge. This is super cool!!! A/F, Boost, Timing, Load, etc. I got in touch with the Aeroforce guys a few months ago to have them get a working gauge for Porsches. I installed the gauge today in my 997.2 Turbo where the sport chrono clock was. This install took around 45 minutes while taking pictures. I did a short drive to give you guys an idea on what this gauge actually does. I am not associated with Aeroforce at all. I just wanted something with this functionality with out the need for extra hardware, line, o2 Bugs and Aeroforce made this happen. Super psyched on this!!!
http://aeroforcetech.com/products_interceptor.html
The Sport Chrono clock requires some force to lift.
Remove the 4 screws with a H10 hex bit
There are 4 small holes around the outside of the clock that have screws with allen key heads holding in the clock. These need to be removed to pull the clock out of the assembly. BE SUPER CAREFUL to not pull on the clock. It will knock the hands off. they are a PITA to get back on. I ended up taping the clear lens over the hands for storage.
Don't use the U bracket with the kit to install the gauge. The 4 allen key screws that were used to hold the sport chrono clock are enough to secure the new gauge.
I dropped a wire down from the top where the sport chrono clock was installed. Looked under the dash by the gas pedal and the wire was bunched up there. I connected the Aeroforce OBD2 line to that and pulled back up through the hole. This was the hardest part of the entire job and it took about 2 minutes.
Here is the gauge installed. This thing is seriously awesome for this car since the computer does A/F and Boost. No extra hardware is required for this to work!!!
Old Mar 16, 2014 | 04:12 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Nice thanks for sharing.
So how much was it?
Old Mar 16, 2014 | 08:55 PM
dewilmoth's Avatar
dewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant futuredewilmoth has a brilliant future
The Turbo has a wideband O2 sensor from the factory? If so, that's cool and I didn't realize that. If not, the O2 reading would be essentially worthless. Cool minimally invasive mod nonetheless.
Old Mar 17, 2014 | 12:59 PM
SamboTT@ByDesign's Avatar
+ rep on Nice work and great write up. Thanks!
Old Mar 17, 2014 | 04:08 PM
AZTurbo's Avatar
AZTurbo is infamous around these parts
I want it but it's not listed on the site for Porsche. How do we order?
Old Mar 17, 2014 | 04:29 PM
kinkkink's Avatar
The car has factory wideband o2. My A/F and boost are dead on from the logs I sent for my tune.
The single gauge is $250. They sell a dual gauge setup with an OBD2 splitter, however I have not tested it on my car but I'm sure it works. I'd imagine they will have it on their site soon. You may be able to get it by emailing them. Try them at sales@aeroforcetech.com
Hands down the best money I've spent on the Porsche.
The gauge has SO many more features/modes. I'll update this thread next weekend when I take the car out.
Old Mar 17, 2014 | 10:26 PM
DOOBEE's Avatar
DOOBEE is infamous around these partsDOOBEE is infamous around these parts
Nice install and notes. I like the chrono replacement and looked into gages in the past. PLX Devices has a similar unit.
I use a bluetooth ELM327 device plugged in to the OBD port and run Torque on my Note3 to get and display the same data.
Old Mar 18, 2014 | 02:52 PM
AZTurbo's Avatar
Just ordered mine today. Hopefully it works on a 2007 TT as well as on your 2010 model.
Old Apr 22, 2014 | 03:54 PM
ilko's Avatar
ilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of light
This looks very cool! I'm ready to pick one up. For 2007 cars their site says that it does not show the boost parameter, is that the case AZTurbo?
Old Apr 22, 2014 | 04:03 PM
kinkkink's Avatar
That seems to be the case with the 07 (maybe 07 to 09). I spoke with AZTurbo and he needed the additional sensor. I personally have it installed on my 2010 turbo and tested on my buddies 2011 turbo. The boost and all other functions display correctly.
Old Apr 22, 2014 | 05:07 PM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
That is cool, nice clean install.
Old Apr 22, 2014 | 05:43 PM
AZTurbo's Avatar
On a 2007 you will need a MAP sensor as they did not have one on the 2007 model. The other models will work without the added sensor.
Get a hold of me, I am selling mine with the sensor which I have not installed yet. I have not listed it but decided to sell it today.
Old Apr 23, 2014 | 06:28 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
great setup
could you tell me if it showed both A/F banks ????
Old Oct 10, 2014 | 06:29 AM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Does this display boost beyond the range of the factory gauge?
Old Oct 10, 2014 | 12:12 PM
GTRNICK's Avatar
It should as its the factory gauge does not read more than 1.2bar.
