Upgrade to Dectanes
Old Apr 3, 2014 | 02:55 PM
dinosaur's Avatar
dinosaur is a splendid one to beholddinosaur is a splendid one to beholddinosaur is a splendid one to beholddinosaur is a splendid one to beholddinosaur is a splendid one to beholddinosaur is a splendid one to beholddinosaur is a splendid one to behold
Upgrade to Dectanes
hello all,
just wanted to share my recent upgrade..LED tails!
these are from FVD (thanks Rhonda)...what better than getting it from a company that is known to support their products and stand by it!
just a few observations..
general quality was good...alignment was a little ...meh.....but nothing a washer or two didn't fix.
no CEL's! hopefully it stays that way. i didn't install the extra resistor packs that were included in the package.
i believe that it really enhances and "updates" the look of the car. for those still on the fence, i say go for it...i think you won't regret it.
cheers everyone!
ID:	355361   Click image for larger version
ID:	355372   Click image for larger version
ID:	355374   Click image for larger version
ID:	355375   Click image for larger version
Old Apr 3, 2014 | 05:12 PM
PHIKEL's Avatar
PHIKEL is infamous around these partsPHIKEL is infamous around these parts
I hope they keep working without issue. I just emailed Rhonda regarding issues I'm having with Depo LEDs . Not sure if they came from FVD or not as they were in the car when I bought it and the previous owner didn't provide me with a receipt. Bottom line I'm having codes so I reached out to Rhonda's for possible help with a work around and her only solution was to buy another set. Somewhat disappointing response. I hope yours stay issue free, they do look great!
Old Apr 4, 2014 | 09:29 AM
kchu221's Avatar
kchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond reputekchu221 has a reputation beyond repute
wow those do look great and transforms the car! im looking to buy the same set in the very near future, did you install it your self?? and how long did shipping take??:0
Old Apr 4, 2014 | 11:19 AM
dinosaur's Avatar
yes its a simple DIY....total of 6 screws really if you think about it.
shipping is ground...so give and take 5 days.
let me know if you need help...we're both local.
Old Apr 4, 2014 | 12:27 PM
kchu221's Avatar
thatnks for the reply! but yes ill definately get in contact with you if i get stuck!
Old Apr 4, 2014 | 12:36 PM
dm620's Avatar
dm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant futuredm620 has a brilliant future
Just installed a set of these 2 weeks ago. I installed both resistors and also removed the ones attached to the light housing and stuck them to the body of the car along with the second resistor. I have heard heat from the resistor is one of the problems so I was being proactive by relocating the main resistor.
Old Apr 5, 2014 | 07:29 AM
PHIKEL's Avatar
I'm going to try relocating the resisters that came with the Depo fixture away from the housing as you have. The other two resistors you just installed, are they the in line type that DelRay shows in his system?
Old Apr 5, 2014 | 10:06 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
It's weird why they just don't step down the amps from the factory. It's a well known and documented issue. Why have your customers go through this step of adding resistors and figuring out where to place them to reduce heat damage and such.
For $800-1000 a pair, the QA is lacking.
Old Apr 7, 2014 | 01:22 PM
dinosaur's Avatar
thanks for the tip! i just relocated the resistors from the lamp housing to the car body...
i initially thought that there wasn't going to be suitable location to double-tape the resistor to the body as the lamp pretty much extends inside the space alloted for it....but i guess it does have a lot of clearance.
Old Apr 7, 2014 | 01:39 PM
SamboTT@ByDesign's Avatar
Nice. And awesome wheels
Old Apr 7, 2014 | 01:58 PM
PHIKEL's Avatar
can you provide a picture of the wires you tapped into for the additional resistors you added?
Thank you
Kelly
Old Apr 7, 2014 | 02:03 PM
dinosaur's Avatar
Thank you
Kelly
hey kelly,
sorry i wasn't able to take photos.... but i didn't add any resistors...i just relocated the main resistors that were screwed at the back of the lamp housing and doublesided taped them to the car's metal body.
the lights came with additional resistors, but i haven't installed those.
Old Apr 7, 2014 | 02:05 PM
PHIKEL's Avatar
Perfect, Ill do the same.
thanks
Kelly
Feelgood MD
Mar 24, 2016 09:35 AM
XLR82XS
Oct 5, 2015 07:02 AM
Weebs
Sep 7, 2015 11:42 AM
faiz
Sep 2, 2015 08:43 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
