Had re-11 tires burned on a track day
Old Apr 19, 2014 | 06:35 AM
Tarasser's Avatar
Tarasser is infamous around these parts
Today I went to track autodromspb
It is only 1km length and has many turns. 1 ring is about 50sec to go. From the second ring I 've realized that's it is becoming harder to turn and stop. I made 1 cool down ring and then start pushing again. The grip last only for 5-6 turns, and the tires flow =(
when I've stoped I sow this
I thought my tires suite for track days, and can last at least for 5-7 minutes hard driving. Am I rong? Now I am thinking for changing Bridgestones Re-11 to Michelin Sport Cup 2! Are they better?
997.2 Turbo pdk daily driving
Old Apr 19, 2014 | 06:38 AM
Tarasser's Avatar
pic are made at home
Just after the driving they looked like this
http://api.viglink.com/api/click?for...tionm.net&txt=
Old Apr 19, 2014 | 08:59 AM
Elephant Chuck's Avatar
Elephant Chuck is infamous around these parts
Those bits of rubber are "marbles". They peel off hot tires during hard cornering and braking.
DOT R tires and slicks do this all time. Street tires tend not to do this.
Drive over marbles on the track with hot tires and they will stick to your tires. Those bits you are seeing may be from other car's tires.
Old Apr 19, 2014 | 01:34 PM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
I run RE-11s all day on the track and they are very good, they get greasy after 22 or so minutes if you are trying to get that sweet spot of PSI. But the key to good traction is knowing air pressure. In a heavy turbo, I happen to find 38-40 HOT will have tires last the best for a session. That chunk of rubber is not your tire but from rubber on the track picked up
Old Apr 19, 2014 | 01:36 PM
Tarasser's Avatar
Thanks! I was thinking the same way!
what about the tires, what tires would you recommend?
Old Apr 20, 2014 | 02:48 AM
Tarasser's Avatar
I have re11 not re11s!!
Old Apr 20, 2014 | 05:36 AM
Winnilaker's Avatar
That was a plural "s" not "RE-11S". I have same tires are you. These are very good track tires, search forum good thread on them.
Old Apr 20, 2014 | 08:20 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
I would recommend starting with a cold psi of 30 lbs all the way around. Tires usually raise 6 to 8 lbs during a session.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
jyupitt1
Sep 23, 2015 06:26 AM
mikespeed95
Sep 14, 2015 09:48 AM
mjacobellis
Aug 20, 2015 09:13 AM
