Airbag light
Old May 20, 2014 | 11:04 PM
TT Surgeon's Avatar
Airbag light
Got that tonight. I was messing with my oem fire extinguisher mount under the drivers seat last week. Is there a sensor or wire down there I could've jacked, a week later?
Old May 21, 2014 | 01:55 AM
W211's Avatar
W211 is infamous around these parts
I changed my wheels and the SRS light came on, ended up being a faulty sensor at the bumper, just coincidence.
Old May 21, 2014 | 02:16 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Probably its the wires under the seat, they are a bit sensitive.
You have to clear it out with Durametric then TURN OFF the ignition remove the key.
wait for 5 secs then turn it back on, it will be ok
Old May 21, 2014 | 09:42 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
but make sure you didnt slightly disconnect a wire. i can send you my durametric Pro for the cost of shipping both ways if you need it.
Old May 21, 2014 | 12:06 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Disconnect battery
Old May 21, 2014 | 03:11 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
If you are lucky you can disconnect and reconnect the battery or use a Durametric to reset the seat, hence the light.
If that doesn't cure it, it's a trip to the dealer to have the seat re-calibrated. I had to go through that when it happened to me.
Old May 21, 2014 | 03:13 PM
TT Surgeon's Avatar
I scanned it w a friends pwis today, turns out its the passenger seat sensor. Dealer/cpo time.
Old May 22, 2014 | 05:43 PM
512bb's Avatar
When the light comes on for the passenger seat, the sensors definitely have to be reset. It's done with no weight on the seat, 20 pounds on the seat, 80 pounds on the seat and a grown man on the seat.
Ask the dealer exactly what process they are going to run and see if you can get procedure steps and also whether they have the right weights. My dealer had all the right weights and etc. I made sure I had all that paperwork and am keeping them, just in case the airbag malfunctions in an emergency. A bit paranoid on my part, but I rather be safe on this one.
Old May 23, 2014 | 05:02 PM
TT Surgeon's Avatar
Thanks for the tip!
Old May 23, 2014 | 09:27 PM
TurboRexed's Avatar
TurboRexed is infamous around these parts
Mine came on about 3 weeks ago when I made a sharp u-turn on a bumpy narrow road
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
Walorus
Aug 18, 2015 01:39 PM
