Front suspension "clicking" in tight turns
Old May 30, 2014 | 02:52 PM
1pennyshort's Avatar
1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about
A few months back I've installed GMG sways and springs on my car and so far I am very happy with the results. Good for street and great on the track.
I do have one problem though. In slow, tight turns I hear a "clicking" sound from the front suspension. I can also feel this in the steering wheel if I turn to full lock (either way) with the car stationary. I was told that the most likely cause is the drop links and I suspect that's the case. They are long, not adjustable and the GMG sway bar is stiffer (I have it setup at medium stiffness).
Is this something others with the GMG setup experienced? Do I just have to get used to it? Would Tarrett front drop links help?
Thanks.
Old May 30, 2014 | 03:23 PM
lexart's Avatar
lexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond repute
If you suspect the drop links, you can test this theory by disconnecting one (just one, not both) drop link from the sway bar end. See if the noise goes away.
Is the noise present only when you take slow turn? Is also present when you go over rough/bumpy pavement? Do you hear it from both L/R or just one side?
BTW, I also run GMG bars with stock drop links but my car is not lowered. I set the front to full soft, rear is set to middle hole . . .
Old May 30, 2014 | 03:31 PM
Interesting, I'll try disconnecting one drop link and see what happens.
It's hard to tell exactly which side the noise comes from, I would say it comes from either side, depending on which way I turn. With the car still, I feel a click in the steering wheel either way I turn.
Now that you mention it, I do get occasional noise when running over a bump at speed.
Old May 30, 2014 | 03:36 PM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
I think it's your top mounts. They might be worn out.
Old May 30, 2014 | 06:54 PM
'02996ttx50's Avatar
i think it's your springs "binding". esp at hard lock turns.
Old Jun 2, 2014 | 09:15 AM
deckman's Avatar
This goes back to the 996TT. I don't think anyone was able to definitively find the source.
Old Jun 2, 2014 | 12:07 PM
replace strut top mount bearings.
#TeamAIM
Old Jun 2, 2014 | 08:08 PM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
My car does it, dealer told me it could be front diff. But 2 years later no issues, I also don't make tight turns anymore.
Old Jun 2, 2014 | 09:56 PM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
i had a similar problem. found out it was my aftermarket rims with tpms valves mounted on the inside of the rim. the valve was catching a plastic inner wheel well trim piece. Just a thought if you are running a different wheel.
cadman
Nov 13, 2025 08:57 AM
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
TrackOne
Aug 20, 2015 12:56 PM
