Turbo over heating
Old Jun 7, 2014 | 12:56 PM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
Turbo over heating
After 2 sessions at Glen, bank 1 turbo is overheating after 6-7 laps. I reset and let cool down and works fine. Any ideas what to look for? It is 82 degrees and sunny.
Old Jun 7, 2014 | 01:05 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
what temp is your engine oil registering? coolant temp registering?
Old Jun 7, 2014 | 01:20 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Oil level full?
Old Jun 7, 2014 | 01:56 PM
Winnilaker's Avatar
I didn't take note of temps, but will next session. Oil was a little low but not real low. Actual error, actuator high temperature bank 1, which is the driver side, correct?
Old Jun 7, 2014 | 01:59 PM
93ls1rx7's Avatar
Hmm that the vtg control...maybe it is sticking.
Old Jun 7, 2014 | 03:35 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
I had a problem with the actuator for the variable vanes sticking. Careful with that - it killed brand new spark-plugs in a few hundred km.
Old Jun 7, 2014 | 06:39 PM
Winnilaker's Avatar
Oil temp was 210ish and water was 175ish. Happened again on last session, happened when I was pushing the throttle hard hitting close to 150mph each time.
Old Jun 8, 2014 | 09:26 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Also check your turbo and intercooler for boost leaks...
Old Jun 8, 2014 | 09:34 AM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
Did you only get the code or did the ECU pull boost, timing, etc. and go into limp mode? Is it possible there is another problem like a bad cat, failed gasket or faulty sensor that is causing or reporting excess heat elsewhere in the intake/exhaust system (think exhaust gas temps) and triggering the code? My limited understanding is that an EGT issue will throw a "soft fault", ie resets when ignition is recycled or even when temps dip back below threshold, but will recur whenever temp parameters are once again exceeded. Obviously, track use exacerbates this problem. I had a similar problem last summer. Car ran great for a few laps, then would go into limp mode for half a lap, then would run great for a half lap, back into limp mode, etc. etc. Gauge temps were normal like yours and nothing abnormal appeared while datalogging. Car ran fine while on the street. Turned out to be a fouled cat combined with track conditions but it had everyone guessing for awhile. Good luck!
Old Jun 8, 2014 | 08:46 PM
Winnilaker's Avatar
I only got the code fault, would that data still be in car if I didn't data log it?. Checked for boost leaks, nothing seemed obvious. Had same problem all sessions today as well. Ran fine for 20 minutes or so and then lost boost, car drove ok, just didn't had top end power.
Sucked when I worked hard to pass some fast guys only to have to wave them by after I lost the turbos.
Here is 1 lap with junked R888s, their last session. Would have been to fun to play all 30 minutes.
Old Jun 10, 2014 | 07:15 AM
Winnilaker's Avatar
Taking to dealer Wednesday, not sure what they will figure out since I won't be able to reproduce unless at the track. Can you track guys make me feel comfortable that these cars can handle aggressive all out driving for 30+ minutes? I have no engine mods except a tune and exhaust.
Will have them check for boost leaks.
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
gulf gt
Aug 27, 2015 10:27 AM
Just Cruise
Aug 25, 2015 10:45 AM
