Nuisance CEL: Ambient temperature sensor
Old Aug 2, 2014 | 06:23 PM
tomb18's Avatar
tomb18 is a jewel in the roughtomb18 is a jewel in the roughtomb18 is a jewel in the rough
So this is the third time I get a CEL: Of coarse, if I didn't have a durametric, I'd be at the shop in a flash.
Turns out it tells me "Ambient temperature sensor:implausible signal". So I reset it and alls well till I floor the car and it starts all over. This time I looked at the temperature: 66.5C.
Ok a little research and the sensor is located on the passenger side in the air duct. It is not there. So if has fallen behind somewhere and I guess when I floor the car, it moves and touches a rad.
So my question: how do I access it? I don't have a lift so getting under the front to remove the pan will be tough. Can you get to the rad via the trunk?
Also, why put up a cel?? Porsche should just log it as a warning and not display a cel.
Old Aug 2, 2014 | 08:29 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Had the same issue but i thought it was in the front wheel well for some reason,had it replaced under warranty.
Old Aug 2, 2014 | 08:41 PM
tomb18's Avatar
warrantee over by 2 days....
Old Aug 3, 2014 | 06:10 AM
jhbrennan's Avatar
CEL or just a warning light? CEL usually a more serious problem most likely emissions-related.
Old Aug 3, 2014 | 07:51 AM
tomb18's Avatar
Cel. The motor light comes on, and the display says to visit shop.
I checked all the modules on the durometric and that's the only one. Clearing it clears the display.
Perhaps the computer uses this sensor to determine some running parameters?
Tom
Old Aug 3, 2014 | 11:46 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
Porsche can be nice as to warranty depending on the dealer.
Old Aug 3, 2014 | 12:02 PM
tomb18's Avatar
Hi
It seems that I cannot push it in the hole. It needs to be unplugged from the cable, pushed in the hole and then connected from the back. Can anyone verify this?
Bmw M3 Guy
Feb 21, 2018 09:29 AM
DBB
Jan 7, 2016 09:32 AM
cayguy0521
Cayenne 958
Oct 8, 2015 12:37 PM
DetomasoGTS74
Sep 7, 2015 09:42 AM
