Fuel Pump relay location ??
Guys, i dont have the sheet thats located in the fusebox cover. i cant locate the fuel pump relay. i think its bad. the fuel pumps are running even after the car is turned off.
anyone have a link to a pic where this relay is located ? thanks
Did you guys ever change your relays? Did your problem go away? How do I access the relay carrier?
I bought replacement relays thinking mine might be bad when one of my fuel pump fuses kept blowing. I ended up not replacing them though. They are a bit of pain to access. From my memory, it is best to remove the driver's side lower dash. They are above and towards the firewall relative to the footwell fuse panel.
Check this post. https://www.6speedonline.com/forums/...2&postcount=17
I ended up being able to access them after I replaced the pumps (fixing the issue) when I had the lower dash off to replace the clutch helper spring and was swapping out the aluminum support bracket the spring sits in.
COBB Tuning
Mar 29, 2016 09:26 PM
turbotuner20v
Sep 11, 2015 12:02 PM
COBB Tuning
Sep 9, 2015 09:13 PM
ECS Tuning - VW
Aug 27, 2015 08:30 AM
